Try removing the battery and card and wait 10 minutes before reconnecting. If that doesn't help, see if the issue goes away by reinstalling the Windows Media Player.
Try this and let me know how it goes..
It could be that the SD card is corrupted as well..Yu may need to either reformat and re-load the songs, or buy a new SD card..
You will need to insert the SD card into a card reader, which plugs into the USB port of your computer. Go to Windows Explorer (right click Start button and select 'Explore'. Now find your SD card from the left side panel (usually after the DVD/CDROM drive). Right click and select format. If your SD card is Ok, then it should reformat. If there is an issue with the card, then you will not be able to format it.
Once re-formatted, you can drag and drop your music files into the card.
@goldflack. Please stop copying solutions, or you will be reported for abuse.
Thats GREAT! Glad to know that everything's working fine now :)
I would appreciate it if you took a moment to "Accept" my solution, if it was helpful to you in resolving this issue.
Thanks in advance,
IrishDruid
Can u clearly explain ur problem....
Try removing the battery and card and wait for some minutes and then
reconnect and check it. If that doesn't help, format ur SD card and reinstall the player software and then try it..........
1) plug the storage card to your pc.
2) open my computer, find the storage
card and if u want to take back up means do it and then right click select format.
3)Its fat32. quickformat, very
simple operation.
Now the SD card is empty and then install ur player softwares and then try
To rearrange the songs properly, follow these steps:
>Open windows media player again
>Click on menu at bottom right corner
>Click on library.
>Click menu and library again.
>Select SD card
Songs should be rearranged properly.
Make a new playlist and sort them out?
I actually have a pda here (media player 10 yeah) and I could make a video for you on that. But first lets make sure I understand your problem. Can you be more spesific?
try reconnecting the sdcard. Also you could try a reset.
Turns out I had windows media player 9 on my pda, might need to upgrade first but heres basicly what it looks for me. and how it works for me.
I hope this helps if it doesn't I hope it helps you to explain your problem in more detail.
Please watch the video I just posted you.
you might need to perform a hard reset - it will remove all your files in the phone but everything on the sdcard will stay there.
that will reset the media player and you should be back to normal unless theres a problem with the storage card.
Well, if you consider the problem solved you may press the accept button on my solution. And ofcourse if you have any other questions feel free to ask.
Try another card. or format it on your pc and try again.
plug the storage card to your pc, open my computer, find the storage card and right click and select format. Its fat32. quickformat, very simple operation, just backup the files on the card first as its going to be empty after this.
you can also format the sdcard in your pda with a 3rd party software like
http://www.softwinter.com/storagetools.h...
Here are the format settings from my 1GB SD card.
Great, can you take a moment and press accept on my solution to close the thread. Thanks alot! good luck and if you need anything else ask me.
I see that irishdruid also wants to get paid from this eh :)
you choose which one of us you want to accept.
I do feel that I put in more work with the video and so on.
When I first the music from the sd card, I could play any tune and shuffle the songs and listen to them all.
Now all I can do is click on the file with the artists name and only play one song at a time.
Did that menu- library, and what comes up is a box with MY DEVICE and IPAQ FILE STORE. no SD card.
Tried that and no joy. Regards.
HP IPAQ 214. Cant get my songs from SD card.
Is it something to do with METADATA.
My SD card has 62 songs on it.I open windows media player.Library comes up. click on my music-all music and nothing.If I then click on menu (bottom right of screen) then click on Open File-SD card-music, I get all the artists names, but not the song titles that I had before. Thanks.
Taken out the battery and card.
I had another problem a few weeks ago when I could get nothing from my SD card. It was solved by changing the metadata file which i did and all worked perfectly. But now I cant remember how I did it.The error message was--An unexpected error occured.
Thanks for all your help. I am now thinking it may be the SD card.
I am not to keen on doing a hard reset.
Took the battery and card out for a while but still no joy. Thanks
No joy by removing the battery and card for ten minutes. Regards.
You can probably tell that I am new to all this. How do I reformat my SD card.Thanks
I format my SD card and transfered the music back on,now everythink is OK.Thanks for all of your help. Great Site.
