If you do not know what an audio output IC is, what would ordering one do for you? And unless you have the know how and special gear there is no freaking way you could ever replace it.
Either have someone repair it for you or go shopping.
The audio output ic is getting to hot due to bad connections or ic failure. Check the speaker wires for shorts, if okay! semiconductor needs to be replaced.
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C.
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
I had the same problem, and I had to replace the fan on the unit. The fan would not turn on at all, so the computer would tell the unit to turn itself off. After the fan was replaced (which is relatively simple) it works like new.
