Professionals working for research proposal writing service can suggest a solution for you.
Win XP :
1.You would need External DVD drive and have to order recovery discs from HP.
2. Connect the Drive to the Notebook. insert the recovery disc(s)into the drive. 3.Tap on F9 while booting, Select to boot from external drive from the boot menu.
Win 7:
1.Tap on F11 while booting to access the HP recovery manager.
2.Click on system recovery under I need help immediately.
You will have to use the restore function. because of it not having an optical drive
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
