2001 Hyundai Accent Logo
Posted on Oct 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i drive my car sometimes it works fine and sometime pick up comes after few seconds causing sudden spped breaks something like petrol supply get interupted or power supply get interupted..
timothy hester
Level 3:
  • Master 760 Answers
  • Posted on Oct 21, 2010
timothy hester
Master
Level 3:
Answers
760
Questions
0
Helped
128515
Points
2337
Could be the tps or maf,have them tested.
TIM...............
1helpful
I am wondering why my car sometimes stalls when I am driving, than after a few seconds it works again.
Something may be intermittently heating up or a connection vibrating and causing temporary failure of the ignition or fuel system. Any recent work on the engine ?
What is causing intermittent lack of power?
seems like it's going into limp mode intermittently i would try cleaning crack shaft sensor. or replace.
Rav4 Automatic Transmission Jerks into Second
check the level of the transmission fluid while the engine is running.
also has the transmission been "flushed"? a lot of shops just use
dextron atf with the additives supplied by the supplier of the flushing machine.
this can cause problems in toyotas.
replacing the fluid with the correct (T IV) transmission fluid
may help.
but if you are having this much trouble it may be too late.
I have a 2005 Chrysler Town and country. Sometimes while driving I will feel a vibration in the gas pedal and hear a squeeling noise coming from the front end. It has happened only a few times, spped...
Have you had your transmission serviced, lately. Something in your drive train may be causing this . However, it is only sporadic. The fluid level may be too low or the pump may be going bad.
My 1991 Toyota Corolla drives fine and then suddenly it starts to hesitate.
mine did the same thing and it was oxygen sensor
since engine light came on there should be an error code
on computer.Get a diagnostic checker or take to a garage and have them hook uo to the diag connector. I bought a diagnostic checker few years ago and it has come in very handy
sure hope this helps!!
2helpful
2answers
1) Engine light temporarily - 2) unknown
1.the engine light will be on when you ignight the car but if it stays on even when you finish you should start worrying. 2. That jerking might be transmission problems.
1993 Ford Ranger Headlights won't stay on
you will probably find the problem stated with a poor connection in the headlight switch plug and is now heating up and looseing conection in a short time.remove the headlight switch and you will see what i mean.
Randomly loses power and sometime dies
1st thing to do is have the system tested for the code that caused the check engine light to come, you may also have a fuel pump starting to fail or many other things, the check engine light may be the key. How many wiles on the car?
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
