I have hooked my xbox up to a broksonic 19 in tv and all i get is snow. cant find a channell
Try Changing the AV cable from HDTV to normal TV unless your TV is HD the cable Setting on HDTV will not work. You have to turn off the system and then change the switch. Then turn on your system.
If this doesnt fix your problem then Either of two things has happend your AV cable has gone bad or the chip that enables the AV cord inside the XBOX has bit the dust. If this is the case you will need to contact MS.
Do you have input/component/game/hdmi/aux channels?
If so you need to go to those to see or hear anything.
