Computers & Internet Logo
Posted on Jun 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need information on cas #Qa050819N0016 - Gateway Computers & Internet
Georgia B
Level 3:
Guru:
  • Master 1,342 Answers
  • Posted on Jun 02, 2008
Georgia B
Master
Level 3:
Guru:
Answers
1342
Questions
0
Helped
879470
Points
3834
Calibrate cas ap-1 scale
www.cas-usa.com/cas.../AP1%20-%2060LB%20Owner's%20Manual.pdf
Error code 2f44 bmw won't start tried to clear but comes back after every crank
Fault code: 2F44 EWS preventing manipulation.
This is a common fault code flagged by BMW vehicles when the EWS (also known as the CAS module or immobilizer) no longer communicates with the DME.
Some of the most common causes, for this condition, is battery failure or ignition key failure.
Many times, a customer will bring a BMW into the shop or have it towed into the shop, and explain that "the car just won't start, suddenly". Upon further investigation, it is common for a technician to find poor battery condition or a failed ignition key.
In the case of poor (low) battery condition. A low voltage level has caused the immobilizer (CAS/ EWS) to lose its alignment with the DME.
In the case of a failed key, the immobilizer (CAS/EWS) cannot "see" the key in the ignition and therefore will not allow the vehicle to start. This is the "no crank" part of this fault.
So where do we start?
Using a factory level scanner, connect to the vehicle. After identifying the vehicle, proceed to the immobilizer module (CAS/EWS) and investigate if the key can be identified. If the key in the ignition slot cannot be identified and the key slot/ receiver is functioning correctly, then the key must be replaced. Typically, at this point, the first thing we want to do is ask the customer if another valid key is available. If so, let's try this first! If not available, a NEW key FROM THE DEALER, must be purchased.
NOTE: Aftermarket keys will not work i.e. E bay etc. The keys for these cars are VIN specific and need to be supplied by the dealer only!
A new key will work "right out of the box" from a dealer. Simply put it in the ignition, allow the vehicle to identify it (give it about ten seconds) and try a startup.
After replacing the key and regaining key identification the immobilizer (CAS/EWS) must be aligned with the DME.
Using a factory level scanner, perform the DME to CAS/EWS immobilizer alignment procedure. Clear fault code(s).
So, what about the battery?
All the above information is based on having strong battery voltage. In regards to BMW vehicles, 11.0 volts is NOT good voltage. These vehicles are designed to operate in the 12.4 to 13.0 (average) voltage area.
Before attempting to start the engine, a technician should perform a battery load test. When working with BMW vehicles, if the battery is marginal or too old (more than three years old) replace it.
NOTE: New batteries for later model BMWs (CIP vehicles from approx. 2004) will need to be registered. With a dealer level scanner, a tech can perform this function.
Note: As time passes BMW will change the way immobilizers are aligned. Typically, this happens when BMW changes manufacturers. If performing a standard CAS /DME alignment does not work, A later procedure is available. With late model (EWS 3 type onward) immobilizers, the tech must perform a three-step procedure. Using a dealer level scanner, carry out 1) CAS reset, 2)steering lock counter reset 3) reset the starter interlock.
Need calculator that does calculas
Some calculators that have a CAS (computer Algebra System) are the following
TI Nspire CAS, TI CX CAS, TI92 and TI 92 PLus, TI 89 Titanium, TI Voyage 200 PLT.
Casio FX Algebra 2.0 PLus, Casio ClassPad 330, 330 PLus, 400
HP 48 G, G+, GX, 49 G+, 50 G
1helpful
How to set up CAS
I am sorry to say, but there is nothing for you to set up. Anu calculator comes with a CAS or does not come with a CAS, and this one does not.
If you want a calculator with a CAS, here is a list of some of them
Casio FX-Algebra 2.0
Casio ClassPad 300/300 Plus/330/330 Plus
HP 50G/49G+/40G39G+
Texas Instruments TINspire CAS
TI Nspire CX CAS
TI Voyage 200PLT
TI 89 Titanium
TI 92 Plus
2answers
How do you find the derivative without values for x
I am not sure I understand what you want, but if I am guessing right, you need to calculate formulas for derivatives, where the name of some variable appears eg= d(x^2)/dx = 2 x.
Sorry, the calculator does not have a CAS, you cannot perform symbolic calculations regardless of the subject (derivatives, integrals, sums of series, factoring polynomials, expanding polynomial products, polynomial division, etc.)
How do I factor using the fx-115 ES calculator? would a problem like 9x^2+24x+16-Z^2 be solvable on this calculator? If not, does Casio sell any calculators that would help me factor this equation?
No, your calculator cannot factor polynomials. You need a calculator that has a CAS (computer Algebra System)
Yes Casio sells calculators with CAS: The FX-Algebra 2.0 and 1.0, the FX-9860GPLUS/GII SD, the GRAPH85 or 80 and the Graph 100+. You also have the CLASSPAD Series 300PLUS and 330.
TI and HP also have CAS calculators.
Texas Instruments
TI 89 /Titanium, Voyage 200PLT, TI92PLUS (discontinued), TI Inspire CAS.
Hewlet-Packard
HP 48G/G+/GX, HP40G, HP49G/G+ and the top of the line HP50G
I need to get manual/user's guide for scale CAS LP 1000 (need to re-program the scale...) Thanks!
you can find the user's manual on the CAS corp. site..here's the link...just scroll down to the downloads section on the left and u can download there http://www.cas-usa.com/lp1000n.html
1helpful
1988 isuzu trooper, 2.6L, 4 cyl. I need to know how to test the CAS. I do believe mine is sick. Also, found about 2TBLspoons of engine oil when I took the dist. cap off. I'd like to know why. Thanks
The crank angle sensor has no individual testing procedure. Diagnosis is by verification of repair by replacing with known good component.
Check to see what the Diagnostic Trouble Codes from the ECM are. There are only one or two that directly relate to the CAS.
There is a small seal for the shaft of the CAS, where the drive gear passes through the body to drive the wheel. If this seal has failed, and at this age, it is possible, then the incoming oil has likely fouled the CAS, and is why the CAS won't work.
Unfortunately, there is no seal replacement. The only way to repair the CAS is to replace it.
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
