Hi Victor - I have the same issue I have exposed the motor and removed the larger belt and the spring but I can not see a way to get the smaller belt over the back spindle (The part the actual motor is attached too) - did you manage to do this? did you have to take the machine apart completely to fit this?
If the dryer is not drying the clothes then you would need to check for the following things— Electric Dryer--- 1.Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working. 2.Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively. 3.Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker. 4.Motor wiring shorting to ground.
Hope this helps...
