Sakar SpongeBob SMS Text Messenger Logo
Posted on Apr 17, 2017
I have saving account no SB01004761 (C.A.Deshmukh )& Current A/C No CBCA01000132 (Deshmukh & Associates ) at your Sangli branch. I have requested for the SMS Facility & it is in operation for my Saving A/C . But it is not being accepted for my current A/C as I have Only one Mobile. As per me, this facility should be provided to the A/C holder on the Mobile No provided by him, even though it is same number. Please arrange the necessary changes in your software to accept same no. & advice your branches accordingly. Regards Er.C.A.Deshmukh Chartered Engineer. M- 094 220 41499.
How do I look at my savings account balance?
You need the services of a banker. Visit your branch and bring your ID such as a driver's license, Current military ID, Indian tribal ID or passport.
Can i use my business savings account the same way i use my current account?
While the current account allowes you to deposit and withdraw
freely, business savings accounts usually are more limited in their transactions and are more focused on the saving and earning percentual yield.
Aug 14, 2013 • Finance
2helpful
We have two circuit breakers, a 70amp double pole and a 50amp double pole. The 70 amp double pole seems to be fused onto the silver bar and unremovable. The 50 amp is removable. The 70 died out on us. ...
You probably should not replace a 50 and 75 with a 125. The problem is that although the 125 would have the capacity to supply the same current as the combined 50 and 75, each branch would be provided up to 125 alone, instead of the 50 or 70 that they were allowed before. That is, the 125 won't trip unless both branches exceeded their 50 and 70 amp limits simultaneously. If at any time one branch is drawing very little current, then the other branch would be delivered up to 125 amps. If it is OK that each branch can receive 125 amps alone, then a single 125 would be OK.
And if you have damage to the bus bar, you will have to replace the whole box.
On the other hand, if the existing wires will reach, you might be better off simply replacing all three boxes with one panel.
good luck, be safe Al K
I want to close my saving a/c of axis bank online is it possible?
Unless you can login to your bank account online then I don't think it is possible. In this case you need to go to a Axis bank branch to close your account, don't forget to take your account information with you.
Top Sakar Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Sakar Toy Expert? Answer questions, earn points and help others
