Toshiba DKT-2020 Corded Phone Logo
Posted on May 30, 2008
Voicemail we just took over a company with the toshiba DKT2020-s I need to access\change the voicemail- can you help?
Stephen Gillmore
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 16 Answers
  • Posted on Aug 11, 2008
Stephen Gillmore
Contributor
Level 1:
Welcome Back:
Answers
16
Questions
0
Helped
3929
Points
33
Dial 600 from your phone. When prompted for your security code your extension number followed by 997#
you will be guided from there
How do we re-set a voicemail on Toshiba DKT2020-SD?
Here is a link that pretty much explains it. However, it says to dial 400 to get to your voicemail system. This can vary in programming. If you have an auto attendant that answers your inbound calls, just dial 999 to get to the Administrator mailbox, and then follow the rest of the directions.
http://www.telelinkcom.com/quickstart_pdf/ToshibaVoiceMailSystems/StratagyVoicemailAdminMailbox.pdf
1helpful
Our company has produced Auto Attendant messages for a client's phone system [Toshiba DKT2020-SD] and need step-by step directions for loading them. The client has not been able to provide these...
You would have to dial your voicemail extension. Usually this extension is 850 or 555. Once greeting starts you need to press *. It will then ask you for the user ID and password. User ID should be 990 and password should be 990997. Once in the mailbox you will have to follow the instructions on entering in your message. Below is a site with Toshiba manuals that may help.
http://www.wedophones.com/ToshibaManualsLead.htm
Toshiba DKT2020-SD phone how do i change the voicemail password
need to reset the voice message password from provider.
if from Toshiba kindls contact their service team
if from 3rd party voice message kindly contact the supplier
I am trying to change our company voicemail and the manual (with the company's contact info is, who we bought the phone from) has walked away. Is there a standard code for setting the main VM greeting?...
What Toshiba Voicemail system do you have? Is it a Toshiba or third party voicemail? Depending who setup you voicemail and what version you have. Mailbox 990 is the Intro greeting "thank you for calling xyz company". Mailbox 991 is the main greeting "press 1 for sales press 2 for tech support etc. If you have a toshiba Voicemail. Need to login to 990 and 991 (need to know passwords) Newer versions you can setup just 991 mailbox for both.
2helpful
Toshiba Strata DK16 e & DKT2020-SD
You did not say what kind of voicemail you have but since you have a DK16e I'll assume it is a Stratagy. The Company Greeting is usually split between mailboxes 990 and 991. MB 990 is the introduction ( Thank you for calling ABC Company) and MB 991 are the instructions ( If you know your parties extension please enter it now .... ). The Admin mailbox to set this up is 999 if you have three digit extension numbers and the default password is 999997#. If this password has been changed then you will have to get a local Toshiba dealer to help you as the password will have to be reset via a computer connected to the maintenance port of the voicemail. If you have a computer already set up to program the voicemail then that is where you will also take care of the Directory issues. If you go to www.wedophones.com and click on manuals, scroll down to Toshiba, click on Toshiba, then scroll down until you see Stratagy Voicemail you will find your Admin Guide, Good Luck and let me know how you make out or if I can help ......mitelmike
Voicemail Reset Toshiba DKT2020
you need to log in to your voice mail. when you hear your voice press * , enter your user id, enter your security code then follow the prompt.
2helpful
2answers
We have Toshiba Digital business phones, model # DKT2020-SD. When the message button is pressed on one of our extenions, it is directed to another extension rather than the the voicemail. The digital...
This is a very common problem with the Message waiting light, it can be used to turn on other msg waiting lights on other phones, or used to call back the voicemail after a message has been left in your mailbox. What you need to do is cancel the message waiting light, the code is Intercom + #409, then you will hear a studder dial tone, do that code from both phones (ext 11 and ext 24) and it should solve your problem. I would recommend after using the code, follow up with leaving a message in each phones mailbox to turn the light back on and see if then when you press it, it will take you to your mailbox.
I hope this helps, post back if not.
2answers
Toshiba DKT 2020-SD without a manual!
The phone you have DKT2020-SD can be used on many different Toshiba phone systems. For a phone all you will find are user guides. You need to find out which phone system you have and look for the manual for the system. All the Toshiba phone systems say "Toshiba" plus the description on the front cover. Example: "Toshiba Strata DK-280"
Not sure what you plan to change but programming can be quite difficult if you have no experience with it. It does depend a lot on which system you have. Many of the newest systems require special programming software.
Top Toshiba Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
