2002 Jeep Liberty Logo
Steven Alan Posted on May 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Folding Mirrors on jeep ltd
Hi all , looking for help with the folding mirrors on a liberty, do belive its a common problem, but dont want to replace the mirrors, as they are like new, and the motor sounds like its working on both mirrors ,they just will not fold?any ideas as to a quick fix?without replacing motors, anybody had this problem before and fixed it?
any help would be welcomed,Oh as I,m in england ,cannot just pop round to a breakers for bits
thanks
alan
  • 1 more comment
  • Steven Alan
    Steven Alan Jun 02, 2008
    hi thanks for the reply, yes have checked the switch & it,s ok, the mirrors did work, just got lazy then packed it, there is no problem with altering the angle of the mirrors that workd fine as does the heated part ,it just the fact the fold back part has gone faulty, i can here the motor working but the mirrors just dont work, was thinking there might be a lug or something thats not engaging of has broken, just wondering if anybody has a diagram of the way the motor moves the mirror? that would be a help
    thanks
  • samaritan183 Jul 15, 2008
    The passenger's side mirror on my 2002 Jeep Liberty is loose. The mirror itself inside the housing is not loose but the entire housing itself. It should stay in a fixed position for use but it is loose and swings in towards the door when the vehicle is moving. It's as if some part is missing that allows this to happen. What can I do to fix it?
    mes
  • Anonymous Jul 23, 2008
    We've had the same problem with our Liberty/Cherokee. It was fixed once under warranty and whatever they did it did not involve replacing the mirror. Sometimes it can be fixed by moving the mirror by hand, to get everything to re-engage, but even that stops working after a while. My guess is something jumps out of place and has to be re-seated, but I've been trying to find out how you do that, too.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 30, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
832
Points
Thanks to stupid design, the only way to fix this is to replace the whole mirror. I had the same problem as Samaritan 183 so I took the door trim off to get at the mirror only to find that the cover over the motor and gears has a clip heat welded in place. So, is may only need a gear slipped back tinto place, but you can't open it up to do it. Haven't Jeep designers ever had their mirrors whacked in a parking lot?
Christophe Thompson
Level 3:
Genius:
  • Jeep Master 1,224 Answers
  • Posted on May 29, 2008
Christophe Thompson
Jeep Master
Level 3:
Genius:
Answers
1224
Questions
Helped
596221
Points
3052
You can order online the mirrors
and have them delievered
did you check the switch for the mirrors sometimes its just a simple fix as replaceing a faulty switch
the switch would go out faster then the conventional mirror would try a replacement switch
  • Anonymous Aug 08, 2011
    The mirror motor engages at the top (round cylindrical bit) but is driven by internal gears which tend to strip as happened to me. The only solution is to replace whole unit (at Chrysler's exhorbitant prices).
Does my 2011 VW passat blue motion 2ltr have folding mirrors
Folding or 'power' mirrors were usually an option not a standard part. Take a good look at the twist switch for the mirror adjustment. There should be a logo printed on it if it is fitted, see photo. To operate them it is usually a push down or in action on the window adjuster switch in the middle position.
1helpful
Wing mirrors keep folding out and wont stop, why? can't find a relay that controls this
Outside Mirror May Fold Out to Far : BMW 328i Common ...
repairpal.com > Problems > BMW > 328iside mirror fold out too far . and how to reset to normal . thanks. Upvoted .... side view mirror keeps folding out in a very extended position when I hit unlock.
When operating electric folding wing mirror on drivers side - folds in and makes a clicking noise - like its trying to fold in past its correct closing point?
no jeep model or year,stated, hopeless to help , that...
if you go to any online jeep part store, jeep.com
and look at the your mirror for your car, you will see what
parts are replaceable, and to what LEVEL
FYI< some bodies of jeeps have sub models and mirrors change.
you can walk in to jeep and look at their screen or
do so online.
on some cars the inside mirror parts are replaceble
others are not.
here is RANDOM picked JEEP
but shows you , just how easy it is too look by self.
http://www.wermopar.com/parts-catalog/jeep/grand-cherokee/2000/limited/4-7l-v8-gas/body-hardware/outside-mirrors
2005 navigator power folding mirrors
The wiring harness to the mirrors is likely rubbed through, pull the door panel off on the driver side first and check the mirror harness.
1helpful
What are folding mirrors on a 94 cutlass? im told my replacement mirror is a folding but im possitive mine are fixed and the housing does not move without breaking.maybe im missing something. thanks
some modles come with folding mirrors, they are called break aways, this is so if some one hits it it will fold, it does not mean that it will not break,, yours has stationary one piece, more prone to breaking.
2003 gmc mirrors do not fold in
The power mirrors are controlled by a module (computer) DDM - drivers door module an the PDM - passenger door module .
Folding Mirror System
Folding Mirror System Controls
The folding mirror system requires signals from 2 separate switches. The mirror select switch must be in the neutral/fold position and the mirror direction switch must be activated to the left/extend or right/retract positions. Both switches are integrated into the DDM and provide direct signals.
Folding Mirror System Operation
Upon receipt of the required switch inputs the DDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function. The DDM will also send a class 2 message to the PDM indicating the requested function. The PDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function.
Power Mirror System
Power Mirror System Components
The power mirror system consists of the following components:
• The driver door module--Class 2 module with integrated switches and requires programming when replaced
• The passenger door module--Class 2 module with integrated switches, requires programming when replaced and also contains the RFA receiver
• The power mirror direction switch--Integrated into DDM and is a 4-position momentary switch that provides a signal input to the DDM for up, down, left/extend and right/retract with a mirror switch activation
• The mirror select switch--Integrated into DDM and is a 3-position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• The left outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The right outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The body control module--Class 2 module that requires programming when replaced, serves as the power mode master and is the main message handler
• The DDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The PDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The memory switch, if equipped with memory mirrors--Supplied power by the DDM and provides a voltage signal to the DDM upon a switch activation
• The horizontal and vertical position sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDM/PDM and provide a variable voltage signal to the DDM/PDM that is proportional to mirror position
• The park neutral position switch, if equipped with memory mirrors--Provides transmission gear selection information to the PCM and is used for memory recall and mirror tilt in reverse functions
• The powertrain control module, if equipped with memory mirrors--Class 2 module that requires programming when replaced and provides Class 2 message indicating transmission gear selection
• The driver information center (DIC), if equipped with memory mirrors--Part of the instrument cluster which is a Class 2 module that requires programming when replaced and is used to personalize the memory recall and mirror tilt in reverse functions
• Fold motor in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
Each of the outside power mirrors contains 2 reversible motors to provide horizontal and vertical movement of the mirror glass. The vertical motor operates the up and down directions and the horizontal motor operates the left and right directions. If equipped with power folding mirrors, each outside power mirror will contain a reversible fold motor to operate the extend and retract functions. Each of the mirror motors are circuit breaker protected.
DTC B1722
The driver door module (DDM) and passenger door module (PDM) switch the mirror fold motor control circuits to battery voltage and ground in response to mirror extend or retract command.
5helpful
Hummer H2 Power folding mirror won't fold
The power folding function of your exterior mirrors on your '04 H2 depends on a plastic gear to collapse those mirrors at the touch of a button. That plastic gear strips very easily. The service adviser at our Hummer dealership said that problem was rectified in later model years with a redesign of of the collapsing mechanism of those mirrors.
I don't mind manually folding our mirrors, and I was afraid to ask about the cost of the parts required to solve the issue. The service guy didn't volunteer the cost of the fix. Not typically covered by aftermarket extended service/warranty plans.
Changing door mirrors on Mitsubishi gto to folding type
Try gtouk.com or 3si.com as it isn't that simple as you need 2 extra wires running to your door and extra relays to control the folding action.
Wing mirrors on 06 plate Golf TDi
Has it ocurred to you that your wing mirrors are not the electrically folding type, most are not. The switch on the drivers arm rest for adjusting the mirrrors will have a separate position for folding if yours fold. The resistance to fold by hand is very stiff as you have to overcome the spring tension, even when folded by hand they do not fold as flat as you might think.
I purchased a 2006 Golf 5 GT Tdi last year it had £5000 worth of factory fitted options but did not have electrically folding door mirrors - hope this helps.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
