SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
SOURCE: I need a diagram for the deck belt on my Cub Cadet
go to partstree.com put in your make &model #.then clickdeck assembly.hope this helps
SOURCE: CUB CADET ZERO TURN Z-FORCE 3-BLADE CONFIGURATION
Under each blade is one single nut holding each blade on. It is not left-hand thread and there is nothing special about it.
Standard thread - Standard hardware - Standard tools. (If memory serves, you need a 15/16" socket to remove these.)
There is no need to index or time the blades. They cannot hit together unless something is bent or damaged on your mower deck.
Hope this helps,
Dolf-
You'll need to look under the deck w/ the mower not running and see why the blades aren't turning. Most likely something is bent (maybe blade) and hitting something. The smoke is probably from the belt slipping and getting hot.
