Powercycle (unplug power) all your equipment, Modem/Router waite 15 seconds then plug back in. If you are having an issue with the ip address not valid you can try these steps
(win xp) Start/Run/Type ncpa.cpl hit ok, You will see wireless connection double click wireless connection this will bring you to the properties. ensure that the connection is assigned by DHCP also check to see if you have a valid ip address
Win Vista/7 Start/Search Bar/Type ncpa.cpl Right click on wireless connection and hit properties. Uncheck Internet protocol version 6 and click on Internet Protocol Version 4 and hit properties/Ensure that obtain ip address automatically is checked as well as obtain dns server automatically. hit ok close out.
Go to command prompt Win XP Start/Run/Type CMD hit ok
Win Vista or 7 Start/all programs/accessories/ right click on command prompt and hit run as administrator.
At command prompt type;
netsh int ip reset reset.log hit enter
netsh int ip delete arpcache hit enter
netsh winsock reset hit enter
ip config /flushdns hit enter and restart computer this will reset the ip address hope this helps good luck
Solve this problem
Checking connection servers...
[CS Raw] Connecting to connection server port '5050'... [FAILED]
*** 'COMPONENT_TYPE_YCP_EX' YCP EX Error: ('FND.0210', 0, 0) ***
[CS Raw] Connecting to connection server port '80'... [PASSED]
[CS Raw] Sending port check command... [FAILED]
*** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0000' ***
[CS Raw] Connecting to connection server port '23'... [FAILED]
[CS Raw] FAILED
*** 'COMPONENT_TYPE_YCP' YCPError: 'PortSelector::AllPortsFailed' ***
