Dishwashers Logo
Posted on Sep 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Door wont close on fdf780 dishwasher - Hotpoint Dishwashers
Anonymous
Level 2:
Champion:
  • Expert 246 Answers
  • Posted on Feb 22, 2011
Anonymous
Expert
Level 2:
Champion:
Answers
246
Questions
Helped
120450
Points
311
I am not sure about your specific problem with the door but if you are ever looking to change the look of your dishwasher or other appliances check out www.applianceart.com
They have decor for every occasion and even stainless steel.
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Sep 30, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1292016
Points
7081
Check the shelf height. If your machine has an adjustable shelf (like mine), then if it slips out of position on one side, the door will not shut.
Try lifting up the shelf.
1 Related Answer
quady
  • 142 Answers
  • Posted on Sep 28, 2009
SOURCE: I have an FDF780 dishwasher that wont spray water
Sounds like wash pump is weak or siezed.
FELL ONTO DISHWASHER DOOR AND NOW IT WONT CLOSE.HINGES MAY BE STRAINED.HOW DO I REPLACE HINGES
Hello friend, thank you for your post!
It sounds like it could be an issue with the hinges. I would recommend having a technician come out to your home to diagnose your appliance properly. I understand that someone fell into the door and the hinges are not closing but there could be another issue with the door. Hopefully this is helpful. -Matt
Kickplate on model KUDG25SH
turn off breaker to it leave one minute and turn back on also make sure door is closed tight and nothing is fouling it from proper closing .
Hotpoint fdf780 flooding at rest
Ya you're right the problem is in the water inlet valve, but try to consider also that this machine is equipped with a digital controller or a so called IC. Better to consult a technician nearest you.
Feb 01, 2014 • Dishwashers
My dishwasher door wont shut
see this causes, and use the common sense. God bless you
When your dishwasher door has a problem, check these: Latch Springs Hinges Door seal Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch. Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs. Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough. Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
5helpful
Samsung dishwasher door lock stuck in closed position
take small flat head screwdriver and on the door were the latch is push the screwdriver in about an inchpull on the open handle at the same time ps unplug it first.
What is code a5 on dishwasher fdf780
its a pressure switch fault...........
cheers
When i close my dishwasher door it starts beeping
you need to replace door switch.adrian,,,,
I have a hotpoint fdf780 dishwasher thats started to leak from the bottom quite near the inlet pipe and puts A-1 in the display. Any ideas? Thanks Peter
Yes. Error A-1 is the Water inlet hose alarm. (I have the manual for a fdf780 in front of me). Guess you have already tried tightenning the inlet hose connection?
Jan 05, 2010 • Dishwashers
2helpful
Sep 28, 2009 • Dishwashers
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
