Computers & Internet Logo
Posted on Sep 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a pap2 device with linksys and cisco systems written over it... constant red light with green light in the ethernet.. and no lights in phone 1 and phone 2 so cant access the IP by dialing **** please help fast i dont know whats happening as it was working fine in the morning.... please help fast
Anonymous
Level 3:
  • Master 3,917 Answers
  • Posted on Sep 28, 2010
Anonymous
Master
Level 3:
Answers
3917
Questions
5
Helped
916660
Points
11199
Either the problem is with the modem itself "with the chip inside" or a virus issue. check for virus or Trojan in your and "do not forget" keep your pc secured.
Please check this links if it helps:-
http://help.expedient.com/broadband/leds.shtml
http://www.dslreports.com/faq/5875
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
1 Related Answer
Anonymous
  • 3278 Answers
SOURCE: I have a pap2 device with linksys and cisco
Hello.
First, reset (power Off and On) your Linksys router and PAP2 device.
If still a problem, and the power light on the PAP2 is red, this would indicate a malfunction with the router and indicate it is not bootable. Contact your supplier for a replacement.
Hope this helps.
2answers
I have a problem with connecting modem and router. The ethernet light turning off after 3-5 sec after the router is turning on. Modem don't see router, like it's not connected. When I connecting modem and...
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first. Best of Luck
2helpful
2answers
Have linksys broadband router model # rtp300, formally used to receive Vonage service. Can this devise be used to connect a second computer in my home?
Yes.
This is a wired router.
you can connect second computer to the router.
You will need to connect the cable to the router's ethernet port and computer.
Click Here to know more about router and network
Linsys voip internet phone adepter PAP2T ip address
pulg phone pin in pap2 device phone1 pin then give internet connection to pap2 then dial from the phone *110# then u can here ip from pap2
Lost my password
Hi Friend,
The Linksys PAP2 Device is a user friendly device.
The solutions is u must reset the router to the factory settings i.e., to default setting
u will be having a reset button at the back side of the router ,hold it for 5 to 10 sec and release the router will be getting on automatically then u can configure again from initial.
Regards,
Ayyasam
Delay ring tone
after dial phone no. just dial # for quick ring tone and for good sound quality just choose preffered code g723 and save it. Hope you will get solution
1helpful
3answers
Hookup with Vonage device
I am going to attempt to give you a solution here. But you must understand a few things before I begin.
First, I would like to clarify that if you have Time Warner internet service, you are on Cable Internet. Not DSL. (This makes a world of difference when it comes to using a router.)
Secondly, you did not specify model numbers of your devices. Therefore I am assuming that you are using the following devices:
If this is not the correct equipment, continue to follow the instructions but be dynamic and adapt my instructions to the equipment you have. It should be similar enough that you shouldn't have any problem easily doing this.
This instruction set is going to begin from a point that is assuming that we're installing all of this equipment from the standpoint of a completely new installation. From the ground up.
Let's begin.
UNPLUG AND POWER DOWN ALL OF YOUR EQUIPMENT INCLUDING THE CABLE MODEM, ROUTER, PC AND VONAGE BOX. Do not power on any of the devices until instructed to do so.
1.) Connect your cable modem to the cable from the wall.
2.) Find the ethernet port on your cable modem. Connect the blue ethernet (CAT5) cable to the ethernet port.
3.) Plug the other end of the blue ethernet cable into the "Internet" port of the router. (Older routers used to also call this a "WAN" port.) It is the only port that is seperated from the rest of them.
4.) Connect another ethernet cable to port 1 of the router.
5.) Connect the other end of the ethernet cable to the network port of your PC.
6.) Connect yet another ethernet cable to port 2 of the router.
7.) Connect the other end of this ethernet cable to the ethernet port of the Vonage box.
8.) Plug in the power adapter of the cable modem. Wait 1 minute for the cable modem to acquire it's signal and set up the connection to Time Warner.
9.) Plug in the power adapter of the Linksys router. It should only take 15-20 seconds to set itself up. (If you have made any configurations to the router prior to this, I recommend pressing and holding the RESET button for at least 10 seconds to give you a fresh configuration state to start with.)
10.) Plug in the power adapter to the Linksys PAP2 VOIP Phone Adapter.
11.) Power on your PC. You should have an internet connection with it.
You see... As I read the configuration you described, I don't think that you're using a PAP2 phone adapter. You said that you connected the "vonage device" to both your modem and your PC. This is not possible with the PAP2 adapter as it only has ONE ethernet port.
I am led to believe that you are actually using the Linksys WRTP54G which is essentially the same thing as the WRT54G, but with Vonage support built-in.
If that is the case, then you will not need to use the WRT54G router. Instead, follow the instructions that I gave you assuming that the router and the phone device are combined into one device. (The ports will still be labeled the same.)
Download the installation guide for the WRTP54G from the product page link I just gave you. You'll find the link to the User Guide on the right-side panel. This will make everything clearer for you if you do indeed have that router instead of the PAP2 phone adapter.
If you continue to be confused, please let me know. DO NOT just give me a poor rating without asking more questions. I am here to help you solve your issue. Not have my rating decreased just because someone is too confused or lazy to ask more questions.
I'm happy to help you. :)
Good luck and let me know what the outcome is. (And please be sure to list your exact model numbers in the future!)
Cyryl
Grand Canyon Tech
Grand Canyon Tech
