Euro-Pro 9105 Computerized Sewing Machine Logo
Posted on Sep 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't get the bottom thread to come up with the needle on my euro-pro shark intelli-sew
Debbi's Sewing Machine Repair
Level 3:
  • Euro-Pro Master 7,365 Answers
  • Posted on Sep 26, 2010
Euro-Pro Master
Level 3:
Answers
7365
Questions
Helped
1744510
Points
19451
Try this
make sure there is a 3-5 inch tail on bobbin thread
make sure there is a 3-5 inch tail on top thread, then hold the top thread tail with your fingers (away from the needle) & with your other hand turn the hand wheel manually on the right side of the sewing machine,, slowly letting down the needle down into the bobbin area & see if the bobbin thread will pick up this way
Euro Pro Shark Intelli-Sew 9110 Sewing Machine. It is not programming is messed up?
It may need a new control board as I doubt the software can be reinstalled. Contact the maker support line and check.
https://www.google.com/search?q=Shark+intelli-sew+euro+pro+9110+reinstall+software
2answers
I have a Shark Intelli Euro Pro sewing machine that jams when I begin to sew. Have taken the bobbin out and cleaned it, but to no avail.
A previous answer on this site from Zann_e for another model of Shark sewing machines suggests that you unthread the machine, remove the bobbin, clean the bobbin chamber, turn off and leave unplugged for 45 minutes and put it all back together again. The previous answer suggests that when there is no tension that you encounter the problem you are posting about. Hope this helps.
1helpful
Required needle for 4oz bonded nylon thread "high-Spec"
a ball point needle size 14 or 16 should suffice
My Euro-Pro Shark machine is not sewing. The top thread is not grabbing the bottom thread therefore it will not sew. I have cleaned, adjusted the settings and nothing seems to make it work..Help !!!
Did you try a new needle (flat side facing rear of the machine)? Sometimes a burr on it or being bent stops it from picking up the thread. Other than that, it may be the timing on your machine and unfortunately it needs to be done by a professional with expertise and special tools.
5helpful
3answers
I have a Shark Intelli Sew 9110 Euro Pro. It was
There is no solution for that problem. My machine was doing the same thing, I returned it for "repair". Got it back 2 wks later and had the same problem. Just the other day, the machine did that, and then something "popped" and now the upper thread won't catch the bobbin thread. I called Customer Service and was told that if I want my machine repaired, I have to send them a check with the machine for $81! Your best bet...get rid of the Intelli-Sew and buy something that doesn't break every month or so!
2helpful
3answers
Euro-Pro Shark Intelli-Sew 9110
you need a new bobbin case, only problem is finding the right one. I am currently wasting hours trying to find one for our 9110 intelli sew which has needle holes punched through it from where it jumps right out. I think lots of manufacturers know fine which parts fit the Euro-Pro but would like all of us to scrap them and go out and buy theirs!
Top Euro-Pro Sewing Machines Experts
Mike Cairns
Mike Cairns
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
