Routers
Problem for Routers
Generic problem for all Routers
Help with internet conection
By lovexxxxxxxx on May 22, 2008
Im sharing the same linksys router to my laptop as my parents pc and xbox 360 it can find my xbox 360 and connect gust fine to it and the pc can get internet but my laptop dosnt plz help thx
Comments:
May 22, 2008
- No I have before and at school with there wi fi and then it stoped so the first time I re installed vista because I only had my laptop for a short time and it worked again then it stoped again so I got fed up with it and thought it my be nice to know why it didn’t connect. yes it has a key to get on but its only for the wi fi
May 23, 2008
- yes there is a on of switch on the shell of the laptop and no i dont accidentally turn it off but i did have a friend say they had the same thing with there laptop happen it work at first then stop and she had it looked at by the geek men and they say she fride her chip or sumthing and that dosnt make eny seance why it can see my 360 but not the internet when im conected or not
May 24, 2008
- my command prompt says
wireless is disconnected
ethernet is connected
adepter # 6 is nothing
adepter # 9 is disconnected
adepter # 12 is connected
adepter # 13 disconnected
i hope this helps
May 25, 2008
- this is what hits me
May 27, 2008
- i dont think so but this is what i got
Jun 01, 2008
- It still is a stubborn laptop and doesn’t wont to connect
Clarification Request
Posted by oldnovii on May 24, 2008
I have no idea how you got that info. Here's what I want you to do and the results I expect.
Go to the start menu and type command in the box. Then right-click on Command Prompt and click Run as administrator. If a User Account Control window pops up, click Continue.
This is something like you should see. Give me these results as they appear on your screen. Here is an example:
There should be 3 or 4 sets of numbers. Give me the list exactly as it appears like the example. The name and the number. If it doesn't come up like this let me know.
Jeff
Posted by oldnovii on May 23, 2008
Hey Lovexxxx....Go to your command prompt. Start>run>type cmd in the box and click ok. Once there type "ipconfig" without the quotes and tell me what it says for the numbers please.
Posted by oldnovii on May 22, 2008
Hi lovexx..... - is this the first time you've tried to hook up your latop to the network? Is the router protected by a WPA or WEP key?
Jeff
Solution #1
posted on May 22, 2008
Somewhat Helpful)
Sirach
Rank: Master
Rating: 76%, 8 votes
If connecting wirelessly are you sure your wireless on/off switch is not accidentally getting turned off and on and do you know how to turn it off and on?
Was this helpful?
Yes
No
Solution #2
posted on Jun 02, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
eill the setings mater even if they have an xp?
Solution #3
posted on May 27, 2008
Not Rated)
oldnovii
Rank: Guru
Rating: 92%, 818 votes
Hey - go back to your command prompt and type this:
ipconfig /release there's a space between the g and the /
then type: ipconfig /renew same space betwen the g and the /
After you're done you can do a ipconfig and see if the numbers aew different from last time. If they are give it a try.
Comments:
May 27, 2008
- That wasn't supposed to be a solution so please don't rate. Just pushed the wrong key.
May 31, 2008
- Sorry lovex....Been ill, still am. Just logged on for you. If you still need help. Try these:
Go Start>control panel>setup and maintenance>device manager. Click on the + next to network adapters. There should be two listed. Your wired and your wireless. There should be no yellow exclamation points or red marks. Let me know if there are. Close that.
In your search box type " control panel ". Then go to Check this computers security status. Turn off your firewall if it's on.
Go back to your search box and type " ncpa.cpl " When you get there, you can right click on those extra adapters #6,9,12,13, etc however many you have like that and click on uninstall. Then reboot and see what happens. If it doesn't work, go to your search box and it should still have ncpa.cpl as an option or you can type it. Right click on your ethernwt connection and click on repair. Then try it. Let me know. Again sorry. Gotta lay down but I'll be watching my mail.
May 31, 2008
- Also, make sure these are set:
Open Network Connections by clicking the Start button , clicking Control Panel, clicking Network and Internet, clicking Network and Sharing Center, and then clicking Manage network connections.
Right-click the connection that you want to change, and then click Properties. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties.
To specify IPv4 IP address settings, do one of the following:
To obtain IP settings automatically, click Obtain an IP address automatically, and then click OK.
To obtain a DNS server address automatically, click Obtain DNS server address automatically, and then click OK.
Jun 02, 2008
- OK. Check your settings against those of your parents for your ethernet. I think that all the options you need to check have been listed in my comments. Make sure all the settings are the same. If they're running XP some of the settings won't be in there but check the ones that are like obtain IP address automatically, obtain DNS Server automatically and so forth. If one of them are running XP, do this: On there machine with XP go to start>run and type "cmd" without the quotes and then hit ok. It will take to a C:>prompt. Type ipconfig and you'll get four lines of numbers. Write them all down. Let me know what those numbers are. Please type them because the last set was sorta hard to read.
We're gonna fix this thing. There's something simple and I'v having a brain cramp. You can get to your side of the network but no further. Do these things please before you give up on me and let me know the results. Thanks.
Jun 02, 2008
- Also, what's the model # of your router and what's the Revision level? It should tell either on the back or the bottom. It will look like Rev C. While you're at it you might as well tell me what version of firmware it has. It probably will just say F/W 1.2 or whatever it is. All the info will be on one tag. Thanks.
Was this helpful?
Yes
No
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
where do i find the essid and key on the 2701HG-B trying to get a HP Photosmart printer to attach
Answer
New installation. I can connect fine to the router, but cannot get out to the internet. Says I have... (More)
Answer
how to setup up a access/bridge to connect 2 routers. I want to make a second router to receive a... (More)
Answer
Need login and password for a Zhone router/modem Model #:6218-I2-200-0CC.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Router Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
