Make sure that your battery terminals and the battery contacts are clean. Check the voltage of the battery and the voltage of the adapter in the battery terminals within the phone.
If you can use a jump charge externally if the battery voltage is below the set level as a last try it will be good. now try to charge for 12 hours, if the battery does not retain charge, replace.
However if the adapter voltages are low replace.
SOURCE: W850i red light prob
When it is red light of death, it either means the bootloader of the phone is faulty (after uploading dodgy firmware updates), or the battery is too empty to start-up, let alone display charging progress. In your case you need to leave the phone charging even with the red light flashing and it will be fine. Give it a few hours connected to the charger.
