I had a serious lack of power on kickdown then the computer displayed EPC (electroic power control) 'return to workshop'.
when i switched the engine off then back on again the computer had cleared but when i went over 2000 revs it went back into epc mode again.
does anybody know what can cause this or how i can fix it.????????????????
regards
gary.
There can be an array of problems that can illuminate the EPC lamp on S-Class 220. A few of the most common faults with these are : HFM sensor, turbo or blocked cats. the best way to check the cats are the remove them and tap them on the ground and if dust falls out then the cats are damaged, if OK, you may have to plug into a diagnostic machine.
let me know how you get on,
bryce
Hello
The engine
and automatic transmission in this vehicles drive train
are fully electronically controlled by a computer called the PCM and
TCM (Power Train Control Module, Transmission Control Module). When a
problem like this or other drive-ability related problems occurs the
computer stores a record of the problem (there are of course some
exceptions to this, like the fuel pump, engine coolant temperature
sensor and MAF sensor for instance) in the form of a fault code in
its memory, to read these fault codes you must have the systems
memory scanned with a special tool. Once the fault code(s) are read
you then must perform the appropriate diagnostic testing to find and
resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL
A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR
HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM
Hello
The engine
(Power Train Control Module). Whenever a problem like this occurs the
resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A
Hello
The engine
and transmission in this cars drive train are fully
electronically controlled by a computer called the PCM (Power Train
Control Module). Whenever a problem like this occurs the computer
stores a record of the problem (there are of course some exceptions
to this, like the fuel pump, engine coolant temperature sensor and
MAF sensor for instance) in the form of a fault code in its memory,
to read these fault codes you must have the systems memory scanned
with a special tool. Once the fault code(s) are read you then must
perform the appropriate diagnostic testing to find and resolve the
problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN
HAS DIAGNOSED THE PROBLEM TO AVOID SPEDING YOUR HARD EARNED MONEY ON
after driving for about 5 minutes the kick down stops working and the engine will not go over 3000rpm even in neutral. If I stop and restart the engine everything is fine for another 5 minutes. Mercedes have changed the Air Mass system, cat converters and fuel filters but problem is still there.
(2002 S320 CDi)
this is ********
