If you want to play dota on Warcraft 3 you need to download the map,
then find the Warcraft 3 folder and open it, then open folder called "maps" and cut the DotA map in to that folder... And when you start Warcraft just find it and play it (be sure you have patch 1.24b).
I dont know are you thinking on DotA 2 or Warcraft 3 DotA...This is the answer for Warcraft 3 DotA.
You must do the following if you want to have dota on your pc.
before downloading the files below. you must download this first. CLICK HERE.You must use this to install the game CLICK ME or USE ME
Download and Install Warcraft III - Reign of Chaos (Click Stahnout, Enter Code and click Stahnout again)
After installing it, Download and install Frozen Throne (Click Stahnout, Enter Code and click Stahnout again)
You will need this file to avoid errors during the game. ClickME ,
after installing you must use this patch to make your dota on latest version. CLICK ME
if you want to download dota maps download HERE or HERE.
Goodluck on your download. Hope my solution help. Please give me feedback regarding my solution for your problem. Thanks.
If playing DOTA is the reason why you want to forward a port from your dlink router, I don't think that it is going to be necessary.
To be able to HOST a game in dota, you need to either be in a network or in a virtual private network.
LOCAL HOSTING - this means that you are hosting a game to PCs connected to your LAN under the same router. All you need to do is go to Local Area Connection in Warcraft TFT then create the game you want to host. If your friends is not able to see your game, make sure that your windows firewall has Warcraft TFT in its exceptions. Or you can turn off windows firewall as a workaround each time you play DOTA.
VPN HOSTING - this means you must have a specific software to use to host your DOTA game so friends can connect to you even if they are not under the same LAN or router. Best example of a software to use is GARENA. Garena is a vpn software that allows you to connect to players around the globe. You need to register a username and password to use garena. Download and install Garena to your computer. Login using your username and password to use garena. Once logged in, choose the room you want to host your game for. Choose the one under your current location (e.g. Choose Singapore if you are in Singapore). When you connect to the room, click Start Game to start your warcraft. You can HOST dota games by going to Local Area network in Warcraft TFT and create your game with a valid dota map. Same in LAN, you need to put Garena on the exception list of your firewall for people to see your hosted game.
1. Open Warcraft 3
2. Head online to Battle.net
3. Go to custom games
4. Look for someone hosting a DoTA game
5. Join the game and let it download.
6. Play and Enjoy!
If that doesn't work, or if no one has a DoTA game running, Message me back, and I will set a time and I will host a DoTA game for you to install.
