SOURCE: How do I change the front and rear brakes on a
Not too hard - Undo the two bolts on the caliper and then seperate the caliper and pull the old ones out. Insert the new ones and put the bolts back in to hold the caliper back together and then install them back on the bike with the two retaining bolts. Use a bit of lock tight (Blue) on the threads. Warning do not let anyone apply pressure on the brakes while you have them off the bike or you will have a mess and/or a problem.
SOURCE: having trouble changing a kick stand spring on my
well the easy way is to jack up bike remove the nut jiffy stand slide it out hook spring slide it back in and tight nut hope this helps
SOURCE: removing stock rear turn signals on 2006 Harley Davidon 1200
I have not removed the turn signals from a model this late. There may be a nut between the fender and the fender strut. You may have to remove the fender to get the turn signals off.
