Samsung DV337 Electric Dryer Logo
Posted on Sep 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will not dry, - Samsung DV337 Electric Dryer
Anonymous
Level 3:
  • Samsung Master 43,501 Answers
  • Posted on Sep 12, 2010
Anonymous
Samsung Master
Level 3:
Answers
43501
Questions
0
Helped
10845576
Points
101584
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
2answers
I have a 1992 jeep Cherokee Laredo 4.0 L6. How do I fix dry starting?
dry, i love new terms for problems my first like this.
  1. dry road.
  2. no beer in hand.
  3. fuel tank dry (buy some, LOL)
  4. coolant dry starts. (testing new engines....)
or what, do add a noun to the dry work,
what is dry?
and what fluid ends the dry.?
My kenmore elite #110.73012181 electric dryer with autonsense feature no longer sensing, keeps on drying for hours after clothes dry when on less dry mode or normal dry mode
The drying circuit has to have a sensor to control heat and the timer controls time (on timed drying). Often sensors fail "open" and dryers stop drying. This sensor or the circuit seems to have failed closed (runs all the time). I suspect the sensor has failed in the drying control.
Reset kenmore dishwasher
The most common "reset" key sequences are:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry).
On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Drying problems
Check the front control panel for a AIR DRY / HEAT DRY switch. Perhaps the switch is in the AIR DRY position. If so and you really want to HEAT DRY your dishes, set the switch for HEAT DRY.
Second, it is not a bad thing to let your dishes AIR DRY. It saves money! Just open the Dish Washer door after the last rinse cycle has finished and let the dishes AIR DRY manually. In a hour or so they can usually be put away.
You can also check for the heating element.Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thank you!
What is the best setting to dry jeans on a kenmore 9000 electric
Use Auto Dry for most things and vary the "dryness" level to more or less depending on the thickness of the material you are drying. Auto is most efficient and will adjust itself for finish time.
Auto dry and select "more dry" before hitting start, for jeans or towels.
6helpful
Dishlex dx 403 does not dry dishes - fan dry on red led
Ther have been a lot of complaints about the drying performance of these machines. One solution suggested by Electrolux is to use the "anti bacterial" wash mode, as this is a higher temperature wash, therefore dishes dry better. If you are using Eco wash or Quick wash, drying performance is not very good- Electrolux recommend leaving door ajar at end of cycle to improve drying. Also, ensure your Rinse Aid compartment is topped up, as Rinse Aid greatly improves drying performance.
-Please note: these dishwashers will not dry plastics and other items that do not hold the heat very well!!
-Also, you should be able to hear the drying fan running at the end of cycle- if not, then you may have faulty fan (uncommon), or control board (more common).
Good luck!!
6helpful
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Top Samsung Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
