Jwin JD-VD149 DVD Player Logo
Posted on May 14, 2008
Need a code
Jwin
A
Anonymous
I have an ibook g4. i need to know how to set up my jwin cam100. what softwares do i need?
Please use the link below to download the software
http://jwin.com/support.asp?type=6&idx=7720
Thanks
Does JWIN DVD players have a universal remote code?
According to jWIN's Support Center, their products do not contain universal codes. Click Here to get direct support from jWIN.
Thank you for using FixYa! Have a great day and please remember to rate this solution.
Best regards,
BearWeb
Need a range of codes for jwin dvd's
I can help you with your URC-3021 Universal Remote Control issues.
I do not see a listing for JWIN DVD players in the Urc-3021 Code List.
But don't give up; many manufacturer's re-use other's control codes.
Therefore, I recommend using the URC-3021 Code Search feature to find the compatible codes to control your device.
Please refer to my posted Fixya Tip One For All URC-3021 Code Search, or any of the Tips posted below.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
1helpful
2answers
I NEED THE REGION FREE CODE FOR JWIN JD-VD-141. THANKS.
With the DVD tray open, press 9735 on remote. A menu will pop up, arrow down to Region, then arrow right to highlight the desired region (0 for all). Press Select, then arrow down to Exit Setup and Select again.
4helpful
Code to configure the Universal Remote for my Jwin DVD player (VD141)
jWIN products do not have a series of uniformed universal remote codes, therefore, they can not be provided at this time.
3helpful
3answers
2answers
Won't play DVDs from asia .. need region code unlock.. help.
1- Open tray
2- Press setup
3- Press 1 3 8 9
4- Use Up/Down key from remote control to change the Region
5- Press setup
1helpful
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
3answers
J-win
Well...I went to the Jwin website and this is what they have posted as far as using a universal remote:
"jWIN products do not have a series of uniformed universal remote codes, therefore, they can not be provided at this time."
Top Jwin Televison & Video Experts
ExpressFiX
ExpressFiX
ADMIN Andrew
ADMIN Andrew
Vinho Xie
Vinho Xie
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
