Intermatic T103 Indoor 120-Volt 40-amp Timer Switch-Double Pole/Single Thro Logo
Anonymous Posted on Sep 09, 2010
Hello I have an older T103 Intermatic which controlls outside lights. It is no longer turning on lights and is making an unusual clicking noise. Can it be repaired or should I install a new one? Chris [email protected] 707-546-4910
A
Anonymous
You can replace the clock motor for $16 ...
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=Wh40&op=search&Ntt=Wh40&N=0&sst=subset
... but if the mechanical timer mechanism is worn out, then that is not repairable. To check mechanism, lift timer dial and rotate tripper pins out of way, then click manual override on-and-off >> if override works fine, and lights come on then motor is probably the problem.
If you buy a new T103, the insides might snap right into old timer box without needing to replace the box. To remove insides, depress retainer spring located at top, tip out timer, and lift to remove. New timer has 4 tripper pins. Save old tripper pins, and tape them inside box.
Testimonial: "Perfect advice thank you!"
2answers
On/off tripper problem with T 103 timer
if it won't trip it, the on pin is not lining up right and u need to take it off and put it making sure it is right. if that's not it u got a bad timer
My Intermatic T103 Indoor 120-Volt 40-amp timer emits a constant peeping sound
Intermatic T103 is mechanical timer with moving gears.
Timer makes audible sound when tripper clicks on-off, but it should not make constant noise unless gears are causing noise.
Turn off power and spray WD-40 on gears and see if problem continues.
WD-40 vapor is extremely flammable hydrocarbon when sprayed, and should not be sprayed on live electric circuits.
If problem continues, turn off power, pull mechanism out and spray WD-40 on plastic gears of clock motor.
Open following links for illustrations of clock motor and removing mechanism.
http://waterheatertimer.org/images/WH40-005-gears-350.jpg
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
1helpful
I just purchased a home that has an Intermatic T103 installed in the garage, how can I figure out want it's connected too?
T-103 is 120Volt timer that can be used to control 120Volt and/or 240Volt loads, for example pools and spas and outdoor lights.
Look at the yellow dial and see if it has trippers attached to dial.
If no trippers are on the dial, then the timer function is off.
Next look at dial and see if it rotates as time passes.
If dial does not rotate, then either the clock motor is bad or electricity to timer is off or timer is not connected to power.
Test across terminals A and 1 for 120Volts will tell if timer is getting power.
Last, move manual override back and forth and see if anything turns on and off.
Open following links for more information:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
Hello I need to replace a paragon model 4003-0 can you tell me what is compatable to this model? thanks maury
As you probably know, Paragon is no longer making timers and parts except defrost timers.
4003-00 is not a defrost timer
4003-00 is DPST 120Volt timer 24-hour mechanical timer
Paragon timers and manuals
http://waterheatertimer.org/Paragon-timers-and-manuals.html
Intermatic cross reference shows that T-103 is replacement for 4003-00
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
T-103 has 120Volt clock motor and can control 1 or 2 - 120V loads or 1 - 240Volt load
I have an Intermatic T103 DPST timer installed now (120v). The clock mechanism has failed. I bought Tork 1103 guts to replace it. The wiring is a bit different. Can u map for me which wires go to which...
T-103 has 120V clock motor with 5 terminals A 1 2 3 4
Tork 1101 has 120V clock motor with 4 terminals L 1 X 2
T103 is DPST and can control one-or-two 120Volt loads, or one-or-two 240Volt loads.
Tork 1101 is SPST can control one 120Volt load
Common ground between these timers one 120 Volt load
Changeover for one 120 Volt load:
White wires T103 terminal A go to Tork terminal X
Black wire T103 terminal 1 goes Tork terminals L and 1 (there is brass connector plate that connects L and 1 - if connector is missing, jumper between L and 1)
Black wire on T103 terminal 2 goes Tork terminal 2
If Load requirement is greater than T1101, Grainger sells T103 clock motor for $16
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How to wire T103
T1101 wiring manual
http://waterheatertimer.org/pdf/110111021103WIRING.pdf
2helpful
I having troble with my t103 timer to turn the lights on manualy i try to set the timer but for some reason doesn't work what can i do ???
T103 Intermatic timer has 120Volt clock motor and can control 120V or 240V Loads.
Wiring for timer is shown on following link:
Troubleshoot T103:
1) Manual override is working correctly, and it snaps crisp and clean, and Load turns on-and-off.
That means timer is basically good.
2) Next look to see if yellow dial is rotating.
If dial is not rotating, then 120Volt clock motor needs to be replaced.
Take photo of wiring and mark wires before starting.
Remove two white wires connected to screw terminals 1 and A.
Snap timer mechanism out of box, clock motor is on back of timer.
Use small star screwdriver to remove old clock motor.
Reattach white wires on terminals 1 and A, tighten screws very tight.
Reset current time: lift and rotate dial until current time lines up with silver pointer.
Grainger sells 125V clock motor:
3) If dial is rotating, but gets stuck at certain times, or runs slow, then replace clock motor.
4) If dial is rotating, and trippers are attached to dial, but timer does not turn ON, then trippers are worn down and need to be replaced.
Grainger sells the T103 trippers
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
5) How Intermatic mechanical timers work:
Dial with ON-OFF trippers is rotated by clock motor.
Trippers on dial contact ON-OFF lever.
ON tripper pushes lever one direction.
OFF tripper pushes lever opposite direction.
Lever moves electrical contacts on back of timer that turn Load ON-OFF.
Manual override lever clicks back and forth with each ON-OFF action.
1helpful
2answers
Have model T103 Intermatic Timer that have been turning on the store lights for the past 20 years. Recently the timer does not turn the lights on in the morning and I have to manually flip the switch to...
Sounds like you need new ON pin
The ON-OFF pins rotate around until they come in contact with a lever. The clock motor pushes the pin forward until it clicks the on-off lever. The pins are softer metal than the lever, so the pins wear out.
If you need a new T-103 timer some day > the new timer mechanism can snap right into the old box without changing boxes.
If the dial is not rotating, then you can replace the T100 series 125 Volt clock motor (the T103 clock motor is 125V)
Intermatic T103 timer wired for 240V
yes u will, but u will have to make sure one of the motor wires are hooked up that way also, in case it has been moved, here is a link with the diagram u need
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t103%20-%20english.ashx
Top Intermatic Hardware & Accessories Experts
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
