Apple iPod nano Logo
Posted on Sep 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After i hit the middle button to turn on my ipod nano, they stop working but when i plug it into a cpu it acts fine. no the lock is not on it, and yes i have reset it.
Bernie Reeves
Level 3:
  • Master 395 Answers
  • Posted on Sep 09, 2010
Bernie Reeves
Master
Level 3:
Answers
395
Questions
0
Helped
158254
Points
1029
Goto the website http://www.felixbruns.de/iPod/firmware/
and download the selected firmware for the ipod model you have. if your unsure if the model / type you can goto http://www.felixbruns.de/iPod/firmware/#
and type in the last 3 numbers of your serial number to find out
if you want to downgrade or upgrade, choose the firmware you want to downgrade to, then go to itunes and shift-click on restore and choose the firmware you want to change to. this will restore your ipod
I have apple iPod 2Gb. It doesn't start. it's display only busy icon. I think's it's frozzen how to sove this problem
How to Fix a Frozen IPod Nano
iPod Nanos will sometimes freeze up, sticking on one screen or not even turning on at all. If your nano is locking up, there are a few things you can try to get it working again.
1. Turn off the hold button. First of all, make sure that that wasn't the problem--don't worry, we've all done dumber stuff.
2. Cold boot. Assuming that wasn't the problem, flick the hold button on and off a few times, and then make sure it's off. Hold down the Menu button and the middle button button for about 15 seconds; this should reset the iPod nano, which may fix the issue. Make sure that the iPod nano is fully charged before attempting this.
3. Recharge. If that didn't work at all, try plugging the iPod nano into the USB port of a computer, using the adapter that came with it. Be sure to plug directly into the computer, and not through a USB hub. The USB needs to provide adequate power for the iPod nano to function, and it may be unable to do so through a hub. The iPod nano should be recognized by the computer; once it is, you simply need to safely disconnect it in iTunes, and it should be functional. If it doesn't show up on the computer at all, give it about 20 minutes, leaving the iPod nano connected to the computer, as the nano may be under-charged, which requires a few minutes to re-charge. If it's still not working, try plugging the iPod nano into a different computer.
4. Try again. If the Menu + Middle Button fix seemed to work, but just cycled the nano back to one of its starting screens (including the "do not disconnect" or the "loading Apple logo" screen), try that fix again. If it still doesn't work, try to charge it for a while, and then try it once more.
1helpful
My iPod turns on but the buttons dont work! They were working just fine then they stopped! How do i fix it?
Try this! http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_nano.htm Difficulty: Easy Time Required: Less than 1 Minute Here's How:
  1. NOTE: First make sure that your iPod’s hold button isn’t on. This is the little switch at the top left corner of the iPod video that you can move to “lock” the iPod’s buttons. If this is on, you’ll see a little orange area at the top of the iPod nano and a lock icon on the iPod’s screen. If you see either of these, move the switch back and see if this fixes the problem.
    If the hold switch wasn’t the problem do the following:
  2. Move the hold switch to the on position and then move it back to off.
  3. Hold down the Menu button on the clickwheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart the iPod nano. You’ll know the iPod is restarting when the screen changes and the Apple logo appears.
  4. If this doesn’t work at first, you should repeat the steps.
  5. If this doesn’t work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
  6. If this doesn’t work, you may have a bigger problem, and ought to get more help.
I have a ipod nano and it will not turn on, I
Try to plug it into charge and push the menu button and the middle button, or hold the Menu and Middle button together until the Apple logo come up and see if it works.
I have an ipod Nano 2gb. It works great when it
you connected ipod with some high energy source or tried to provide a high energy from it e.g you connnected it with speakers,or head phones other than ipod. ipod works fine when attached to computer because it acts as an usb device at that time. go to Ipod shop and replace a chip inside it which is blown
My ipod nano is completly dead
"I figured it out with the help of other peoples problems. I pressed the menue and middle button at the same time for about 8 seconds until the apple came up. It took doing it three times. Works just fine now!"
That's an answer I was gonna say. LOL
1helpful
3answers
My ipod nano wont do anything
Press and hold the center button while pressing down on the menu buttton. The Apple logo will appear. This will reboot your Ipod.
If that doesn't work, restore your Ipod to factory settings by plugging your Ipod into Itunes and select restore to factory settings from you Ipod settings in Itunes.
Ipod problems
try your hardest
4helpful
4answers
Help with ipod 8gb nano
Reset your Ipod using the following procedure:
Turn hold on (lock)
Turn hold off (unlock)
Hold in Menu button and middle button until Ipod shuts down and starts up again.
This should remove the lock on the Ipod.
11answers
Applie ipod nanao
hi your ipod will shut itself if no action is on you can determine the period of time that will happen good luck
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
