After you set the lock, you must use your pass code
to view a locked program, view the locked TV, view
a locked channel, cancel the lock, or enter the Lock
menus.
If you forget your pass code, you can view the locked
TV without entering your pass code. When you are
prompted for your pass code, press the number 9 and
QV keys on the TV remote control at the same time. This
process temporarily unlocks the TV.
When entering the Lock menu, this process deletes
your old pass code and prompts you to enter a new
pass code.
• You can either enter a new pass code to open the
Lock menu and make changes or press EXIT to close
the menu.
• If any of the locks are turned on and you exit the
menus when prompted for a new code, the old
code and all lock settings are retained.
• If all locks are turned off and you exit the menus
when prompted for a new code, then the previous
code is erased.
OK.
