20 Most Recent Mitsubishi WD-65731 65" HDTV Questions & Answers
It may be the color wheel.
Mitsubishi... | Answered on Aug 02, 2017
Could be an open internal fuse or power supply failure
Mitsubishi... | Answered on Jun 25, 2017
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. .
Mitsubishi... | Answered on Nov 13, 2016
You have a problem with the Formatter Board. This is placed between the Light Engine and the Fan. If you are planning to do this your self, before you buy make sure you get the right part since there are 2 different boards. This part cost about $60 and it is relatively easy to install. It requires patience, latex gloves, pointy pliers and both types of screw drivers.
Mitsubishi... | Answered on Jul 01, 2016
the connector itself can be replaced but I would also make sure the lamp fan is running properly and isnt full of dust. that is what usually happens.
Mitsubishi... | Answered on Oct 02, 2015
Hello, have you checked the lamp? If not, unplug you tv and here a link to a video on how to do that.....tks.... https://www.youtube.com/watch?v=tPmZMzGRK-s
Mitsubishi... | Answered on Jan 31, 2015
Hello, there are several things, a bad ballast board that provides the lamp with it's voltage to run it. Also a bad power supply can cause it. a bad Color Wheel will also stop it from coming on, if you heard a high pitched squealing sound before it went out, the color wheel would be my best guess.....tks
use the original remote to change the SOURCE to HDMI
Mitsubishi... | Answered on Jan 10, 2015
it sounds like you might have pinched a wire or something. Hopefully nothing serious has been damaged. Open it up if it is together and check ALL of the cables that go to the light engine and such and make SURE None of them have been pinched or shorted against the frame. Then after all is clear--try the power again.
Mitsubishi... | Answered on Dec 06, 2014
You can adjust how your television displays in the settings menu. You will have choices like (letter box, 16:9, 16:10, 4:3 etc) these setting are your aspect ratio.
Mitsubishi... | Answered on Aug 23, 2014
Try a "REBOOT"
Reset, Initialization &
Option Menu
Front Panel Reset & Initialization
Many customer generated symptoms, intermittent symptoms
or symptoms that cannot be duplicated can be resolved
by performing resets or initialization from the front
panel. To avoid making nuisance service calls that may
not be covered under the warranty, ask the customer to
perform the following functions before going to their
home.
The most common are:
• System Reset (Re-boot)
• A/V Reset (Resets Customer Audio/Video
Settings)
• Initialization (Resets all customer options,
settings and menu items)
Use the Front Panel Guide as a reference to quickly
perform the desired function. Note: Button location may
differ by model.
The Reset - Initialization Guide details all resets and initialization
functions.
Front Panel Guide
FRONT PANEL
1) SYSTEM RESET1 - Reboots Set
(Same as Cycling AC Power)
Power LED will flash for about
1 minute.
2) A/V RESET2 <FORMAT+GUIDE>
Resets all Customer Audio/Video Settings
FORMAT GUIDE INPUT
ENTER CANCEL
SYSTEM
RESET
MENU
VOLUME
ADJUST
CH
ADJUST
3) INITIAL2 <FORMAT+INPUT>
Resets all Customer Menu and
A/V Settings
LED DIAGNOSTICS3 <INPUT+MENU>
In case of failure, a 2 digit error code will
be indicated by the POWER/TIMER LED.
1 Perform while the set is either On or Off. (See section on LED Diagnostics)
2 Perform while the set is On.
3 Perform while the set is Off.
Mitsubishi... | Answered on May 15, 2014
Make sure the speakers have not been turned off in the menu. If not--the amp chip in the Tv could have been killed. Along with a fuse or resistor in line with it. Not usually a hard problem to fix.
Mitsubishi... | Answered on May 08, 2014
Is the lamp door on? Is the lamp mounted correctly?
Mitsubishi... | Answered on May 07, 2014
Mitsubishi WD-65731 65" HDTV Logo
190 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
mitsubishi tv wont turn
  • Televison & Video
