After typing password, the computer response " valid password" the system start up. it wont open the windows
Windows Password Buster is an easy-to-use Windows Password Recovery Tool. It is used to recover lost user and administrator passwords used to log on to Windows 7/Vista/XP/2008/2003/2000. Just 3 simple steps, you are allowed to access to Windows again and can reset a new password.It's a fast, easy and efficient solution to recover your forgotten or lost Windows password. Windows Password Buster family now has 2 Editions. http://www.password-buster.com
Firstly windows has an account called "administrator" which doesn't normally show up on the welcome screen but you can get to it either by booting in safe mode (it does show up on the welcome screen when in safe mode) or by pressing ctrl+alt+del at the welcome screen to get an old fassioned login dialog. Often this account will have no password on it.
If the administrator account is locked out or has a password on it then there is a third party password reset and account unlocking tool available from http://www.windowsloginrecovery.com
Make sure you are using the correct password. Make sure you do not have the Caps Lock on.
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers.
If you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts .
You have to be the computers administrator to change any values on any hard drive on your computer.
Click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box.
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7.
Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
Click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
or if its password protected
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
or Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Windows Password Cleaner
Available in Live CD to run offline
This is a utility to blank the password of any user that has a valid local account on your Windows system.
You do not need to know the old password to blank the password.
hope this helps
To open the set up page of the router of the
router , one of your computer should be able to go online through the
router.
It could be a wired computer or wireless
computer.
If it is a wireless
computer then make sure that the computer is connected to your own
wireless network.
Do not change any wireless
settings on the router using a wireless computer.
OK
! Now you have a computer online through the router and you want to
open the set up page of the router.
First step is check the IP
address of the computer.
Check the IP address and the Default gateway on the computer.
For Windows XP
START ==> RUN ==> type in cmd
in the RUN box==>
click OK or Hit ENTER . You will see a black window that is a command prompt .
In the black window type in " ipconfig " ==> and Hit ENTER on your key
board .
For Windows Vista and Windows 7
click
on START ==> type in cmd in the start
search
box ==> enter ==> you will see the black window. Type in " ipconfig "you will see a lot of
information. Try to find out the local area
connection IPv4 address .
Note
down the Default gateway number.
For MAC OS
Click APPLE
icon in the right top corner of the computer. Go to System Preferences
==> go to Network ==> you will find the option Built in Ethernet or Airport whichever is
connected. If you go to that you will find the Ip address and router
Address.
The default gateway is the IP address of your router.
This IP address of the router will be used to open the set up
page of the router
Now you got the IP address
of the router.Open the Internet Browser ( Internet Explorer, Firefox,
Safari )
In the Address bar of the browser Type the IP address of the
router.
Do not type http:// or www
just type in the IP address only.
It will
ask you for the user name and the password of the router.
This is the User name and
the password of the router and NOT
the wireless password. On a wireless router, there are 2 passwords. One
is to access the router and the other one is for the wireless network.
For most of the routers the default password
will be " admin " . for some routers the default password is " password
". For Linksys router the default password is admin and no user name.
I'm sorry, can you describe your problem in more detail?
