SOURCE: Got a Campbell Hausfeld gasless 80amp welder. The
Check the tension on the drive wheel, you also might need a liner, they are fairly inexpensive
SOURCE: Type of oil for pressure washer pump.
any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
SOURCE: Campbell Hausfeld extreme duty 4 gallon air
check for a crimped or damaged line going to the presure switch or it might b the presure switch itself
SOURCE: pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
the unloader valve is deffective , this has a small metal rod which activates a microswitch to turn the machine off , replace the unloader valve
