SOURCE: Black & Decker 18" Electric Lawnmower not getting any power
open up the top cover of the mower & inspect the armature commutator & brushed if not broken.also checked for loose connection on the rectifier,extension terminal on the switch handle then the switch the last to checked ig any burnt on the terninals too. this are common probel may occur if mower not running.
SOURCE: Black and decker mower switch wiring
I have a Black and Decker Electric mower #M2370, which I would like to use this year before moving to a condo. Last year, the mower was stopping and starting depending on how the lever was positioned. I suspected the wiring so I removed the on-off switch lever. The wiring appears intact. Part of plastic inside the lever maybe broken. Can i use the mower without the lever by just pushing the black button?
SOURCE: Black and Decker Electric mower #M2370 lever
I posted a question just a few minutes ago similar to this. It's probably a broken bit in the housing around the switch which won't allow the switch to stay in place when the lever is activated. I asked if it was possible to find replacement switch housings for these older models. So far, most online part places and B&D say they're obsolete, but I'm hoping someone out there has some spare parts.
SOURCE: mm850switch for black decker wher do wiring go
Here is a picture of where the wires go on the switch.
SOURCE: I have a Black and Decker CM1200 Type 1 electric
I had the same problem with the plastic post breaking, but opted to go the upgrade route. I just took a look at the old clamshell a minute ago and the black wires go on posts 1 & 3 and the white wire goes on the 4th post. There should be a red wire on the second post. The black wires are different lengths which I assume prevents someone from attaching the wrong black wire to the wrong post.
Hopes this helps.
Bill
