Procedure to remove commwarrior from Nokia 66xx which is proved beyond doubt.
This or similar prodecure might be useful for other .sis phones.
Please
follow this procedure:
1] Take out memory card.
2]Charge battery full.
3]Press and HOLD a) 'send' button on top left (green). b) Digit "3" button
c) '*' button.
4]You may require assistance from another person for next
stage. Keep holding the three buttons as mentioned above and now press
Power on button (at top) to switch phone power on.Keep holding ALL FOUR
buttons.
5]Now should now see a change in screen.A black strip starts from
left to right and you should see the words "formatting" written.
6] You can
now release all buttons and relax.Soon the formatting is complete.
7]Your
phone is now free from virus and adwares.
Additional steps to
be taken:
1]Scan and format your memory card using a card reader with the
help of antivirus installed in computer.
2]Insert the memory card in phone.
Format it again using using built-in software of phone ,click 'card memory'..
3]Your phone is now ready for normal use .
4]You should install a good
Antivirus in the phone.The FSecure can be downloaded on your Memory card thru
PC from
www.fsecure.com .Its free as long as you do NOT Upgrade or
register.
HI dude, I recommend u to put a latest updated antivirus software in ur cell phone. It will help u to remove virus. If it dont work, alternate is to format ur phone memory and MMC. If u need information about its effect, process to do it, etc. Contact me!!! ==================================================
Kindly send me feedback and rate my solution
Be sure to post a clarification request for ur problem after it is solved.
================================================ SAJAN([email protected]/[email protected])
Hi, Unfortunately you have been infected with a Virus perhaps via Bluetooth perhaps COMMWARRIOR. I would suggest to use this free tool removal shall it be the case. http://symbian-freeware.web.id/symbian/security/netqin-commwarriorc-removal-tool Shall it be another virus you can see what is the application running in background and look with google for a removal tool. Regards, Paolo
ur phone or mem card contain virus.. the easiest way to recover this is first put ur mem card in card reader and format it seperatly. then format ur phone seperately. there are two ways of 6600 formating !. use the coad (*#7370#) if u know ur security code. 2. if u forgot ur cade then switch off ur phone press #, 3, and dial call button at the same time and holding these buttons press switch on button n hold it. note::: hold these four buttons uptil formating doesnt start.
then insert ur formated memory card in the phone (100% working) i tried it.
WARNING format will cause deletion of ur cont nos , messages , images, softwares, videos, and all other data.
i have the same proplem but i found a solution
try to install kav antivirus , if this didn't work , go to messaging , options ,settings,multimedia message ,access point in use then select none ,the phone will show an alert message select yes
NOTE; Nokia 6600 runs on symbian OS S60. Most virus threat for this OS are very rare and can easily be prevented. And installing an antivirus will just slow down your cellphone. A few tips to prevent any virus on your cellphone: *Turn on you bluetooth only when needed, the known virus on symbian phones is transferred via bluetooth. *When you received an unknown file (mostly via bluetooth) from someone you know or do not know, don't open it unless you are sure what the file it. *be careful in installing apps/games on your phones, get or download from legit sources.
always enter virus to another phone when i start bluetooth of my mobile the massage is like sex,love etc and also not connected the Internet throught the bluetooth and also not connected the bluetooth to another phone
hi its a very common problem with 6600. u should flash ur mobile from a certified mechenic.OR u must try this method: first switch off ur mobile and switch on ur set while pressing (star key),(dial key or green key)and(number 3 key) till formating screen appear.after appearing formating screen leave the button and let format ur handset.
plzz rate me
Thanks Guys. Both your solutions were the right approach..
