My Zebra TLP 2824: The first tag always starts in the wrong place of the tag, leaves a blank tag after that, and then proceeds to print every remaining tag perfectly! Any ideas?
The spool is fed correctly. I've checked printing preferences > stock and set the size in both the Printer Properties, as well as in the design of the tag. My tag is 2.25" x 1.0".The spool is fed correctly. I've checked printing preferences > stock and set the size in both the Printer Properties, as well as in the design of the tag. My tag is 2.25" x 1.0".
You can't post conmments that contain an email address.
are you sure that your software isn't causing it to spit out weird labels in the beginning? Try printing form a different program.are you sure that your software isn't causing it to spit out weird labels in the beginning? Try printing form a different program.
I assume by double tags you mean 2 labels across the roll. You need to tell your software that the roll is 2 across. If using the software that comes with the printer, Zebra designer. Set your label width to twice the single label and copy the barcode so that you have 2 across the label, then print
