Honda Pressure Washer PSI 3000 Logo
Posted on Aug 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Low pressure when spraying, inlet water is good.
Anonymous
Level 2:
New Friend:
  • Expert 128 Answers
  • Posted on Aug 31, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
128
Questions
0
Helped
58424
Points
370
Try taking off water hose an in that water in let spray wd 40 while it is running thats the best advice i can give you do it for like 2 minutes
2answers
Spray arms not getting good spin following circulation pump replacement
I would say that you still have blockage in the supply line or a fitter coulnd be blocked or in the spray arms . I did google this and that was I came up with ..
Mar 20, 2023 • Dishwashers
1helpful
My 2 year old frigidaire dishwasher is not filling up with water, goes through cycle but no water is coming out, valve is open all the way?
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Click on : Inlet valve
Jan 25, 2013 • Dishwashers
Is there anything that needs cleaned
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Jan 22, 2013 • Dishwashers
1helpful
Why is no water spraying on the dishes? There is water in the bottom of my dishwasher and it is draining properly, but after a full cycle before drying there is no water on the dishes and detergent is...
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
Not rinsing clean
Jan 12, 2013 • Dishwashers
I have a BeaumaticBKD46W When progam selection starts the machine no water goes in
Dishwasher hums but does not start
Dishes not cleaning
The dishwasher is not getting water
Doesn't pump water
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Thank You for using Fixya
Top Honda Garden Experts
Sean Wright
Sean Wright
john h
Jesse Walters
Jesse Walters
Are you a Honda Garden Expert? Answer questions, earn points and help others
