Lol. Good answer Tom. When looking at the contactor does only one side pull in and the other is bridge together (single) OR do both sides pull in when energized (2 pole)
We cannot see the product you are asking about
Example single throw switch is household light switch ..., flip the switch either direction and load turns on-off.
Example double pole switch is 240 volt double breaker... flip the breaker and two wires turn on-off.
Example triple pole switch is any 3 phase contactor or 3 phase timer ... flip the switch and three wires turn on-off
The 030 model is a 2.5 ton system, so it is not going to utilize a very big contactor. If you're not that familiar with wiring, take a picture of the contactor, turn the power off to the outdoor AC, make notes on where all the wires are attatched & remove all the wires. (Note, you also need to turn off the indoor unit which supplies 24 volt control voltage to the outdoor unit...in other words, turn off you furnace power). Remove the contactor, take it to a local electrical supply house & they will match it. Replace it by reversing the above steps. If you are deadest on ordering online, look @ the white sticker on the side of the contactor in your AC for the ratings. Really the only thing you need to find is the VA rating. On a 2.5 ton system, it is probably only about a 20VA. Get a double pole contactor (brand doesn't matter), 24 volt coil, with the rating on the existing contactor (if you are not sure, a 30VA contactor will do) When it comes in, plug & play.
Use a test light at the contactor to see if the switch and wiring are good.If you see an input from the switch up to the contactor,make sure the connections are all clean on the control input terminals at the contactor.(The contactor is the device that changes the polarity of 12V to the winch to extend or retract-essentially a double throw double pole relay).
chech the voltage going to the contactor if it is less then 21 volts i would change the transformer. sometimes the contactor will chatter because it is not getting enough voltage.
I havent had luck in finding a part list for you but have you tried to look at the label on the motor(s) to find the capacitance? Or try on the existing capacitor? Dual caps are usually listed as 35/5uf or 35/5MFD on the actual part. There are only a few variances of contactors for residential systems normally 30-40va single pole single throw (spst) or 30-40va single pole double throw (spdt) singe throw contactors have four contacts for 220v and double throw contactors have two contacts for 220v and a constantly hot leg.
Usually when you replace the contactor, you do it by the number of poles and the amp rating on the contactor and the coil voltage,
for instance most AC contactors are 2 pole, 25 to 50 amp and 24 volt coil.
If you look on the contactor you have it should have the amp rating on the side and coil voltage is usually there also and you can look at the contactor to see how many poles.
I don’t believe changing the contactor to a double pole contactor will
solve this problem. It appears by your description that bugs are being
attracted to the contact points on the contactor. Changing to a double
pole contactor will not eliminate that problem but only provide another
contact point for the bugs to be attracted to. The most effective
solution would be to replace the current contactor with a sealed design
where the contact points are totally enclosed. Enclosed contactors are
completely enclosed protecting it from bugs and dirt. These type of
contactors are available in the single pole design so no further wiring
modifications are needed. You can consult a professional A/C service
company like mine for more information and assistance.
Hope this helps. Let me know if there's anything I can do for you!
