Sport & Outdoor - Others Logo
Anonymous Posted on Sep 03, 2010
Speed control box and solenoid location on club car ds model 2004
Anonymous
Level 3:
  • Master 3,917 Answers
  • Posted on Sep 03, 2010
Anonymous
Master
Level 3:
Answers
3917
Questions
5
Helped
916651
Points
11199
Hi
Please check this link bellow for the wiring diagrams,if it helps:-
http://www.vintagegolfcartparts.com/cgi-bin/gallery/gallery.cgi?Category=100020
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
1999 Infinity. Where is the fuse that supplies backup/memory power to the E.C.M. on it.
Question edited for clarity and toss in some CAPS.
There is nothing that backs up memory. When you disconnect the battery, all memory is lost, which is why it is important not to do it!
You don't tell us the model? Is it a secret? All questions need 'year make model' as the FIRST 3 words.
If your have a 1999 Infinity I30, the ECM Fuse is Fuse 58.
58 10 Engine Control Module (ECCS), Mass Air Flow Sensor, Crankshaft Position Sensor, Idle Air Control Valve (IACV-ACC) Solenoid Valve, Ignition Coils, EGR, EGR Volume Control Valve, EVAP Control System Pressure Sensor
Infiniti i30 (A32; 1995-1999) fuses and relays
Fuse Box Diagrams https://fuse-box.info > infiniti > infiniti-i30-a32-1995-...
Fuse box diagrams (location and assignment of electrical fuses and relays) Infiniti i30 (A32; 1995, 1996, 1997, 1998, 1999).
Infiniti i30, i35 (A33; 1998-2004) fuses and relays
Fuse Box Diagrams https://fuse-box.info > infiniti > infiniti-i30-i35-a33-1...
Fuse box diagrams (location and assignment of electrical fuses and relays) Infiniti i30 / i35 (A33; 1998, 1999, 2000, 2001, 2002, 2003, 2004).
2004 Dodge Dakota. It down shifts hard and now it won't shift out of 2nd gear and I have code P0734 and the fluid level is good. Where is the solenoid located?
Question edited for clarity and spelling 'solenoid'.
Question moved to model category.
It may not be the solenoid, it is a speed sensor error related to 4th gear.
The P0734 code stands for "Gear 4 Incorrect Ratio." It's logged when the PCM detects that the RPM of your input speed sensor doesn't match the expected RPM in 4th gear.
Aug 17, 2023
P0734 Code: Gear 4 Incorrect Ratio - CarParts.com
More here
https://www.google.com/search?q=Dodge+Dakota+P0734
Where is the fuse located for the braking system in a 1994 Nissan Quest minivan
Fuse 12 for the brake switch, but it covers a lot of other things as well that would be very noticeable.
Automatic Speed Control Device (ASCD) Brake Switch, Data Link Connector, Combination Meter, Heated Seat Relay, Park Neutral Position Switch, Display Unit, Steering Angle Sensor, Display Control Unit, Navi Control Unit, Back Door Control Unit, Sliding Door Control Unit RH/LH, Sonar Control Unit, Daytime Running Lights, Hands Free Telephone
Nissan Quest (V42; 2004-2009) fuses and relays
Fuse Box Diagrams https://fuse-box.info > nissan > nissan-quest-v42-2004...
Here you will find fuse box diagrams of Nissan Quest 2004, 2005, 2006, 2007, 2008 and 2009, get information about the location of the fuse panels inside the car ...
Missing: 1994 ‎' Show results with: 1994
1helpful
2answers
Where is 1-2shift solenoid valve located on a Saturn Vue 3.6
The 1-2 shift solenoid valve on a Saturn Vue 3.6 is typically located in the transmission. The exact location of the solenoid valve can vary depending on the year and model of the vehicle, but it is commonly found inside the transmission's valve body. The valve body is the area of the transmission that houses the shift valves and controls the flow of transmission fluid to control the gear shifts.
It's important to note that accessing and replacing a shift solenoid valve on a transmission can be a difficult and complex task that requires special tools and knowledge. It is not recommended to attempt this repair unless you have experience working on transmissions and have the proper tools and equipment. It's also important to consult the Saturn Vue 3.6 service manual or a professional mechanic or transmission specialist to have the proper steps and safety procedures to follow.
Where is the purge control solenoid and powertrain relay located on 2004 Envoy SLT 4.2L?
Powertrain relay ? Maybe you mean IGN 1 relay ? This supplys B+ power to the coils . relay # 58 in the under hood fuse box .
Is there B+ voltage at the coil's pink wire ?
Evaporative Emission (EVAP) Canister Purge Solenoid (LL8)
On the left side of the engine block
Engine Controls Component Views in Engine Controls - 4.2L
Engine Controls Connector End Views in Engine Controls - 4.2L
Evaporative Emission (EVAP) Canister Purge Solenoid (LM4)
On top of the engine, toward the front
Google picture of solenoid so you know what your looking for .
Where is the cruise control fuse located?
In the SJB - smart junction box , Under the dash ! There are three fuse's - F2.27 10amp - F2.32 10amp - F2.17 15amp . Is your air bag light lit ?
SECTION 310-03: Speed Control 2004 Taurus/Sable Workshop Manual DESCRIPTION AND OPERATION Procedure revision date: 07/02/2003 Speed Control The vehicle speed control system consists of the following components:
  • Brake pedal position (BPP) switch
  • Speed control actuator cable
  • Speed control switches
  • Speed control deactivator switch
  • Speed control indicator
  • Smart junction box (SJB)
NOTE: The clock spring provides the electrical interface between the steering column wiring and the speed control switches in the steering wheel.
The inputs to the speed control actuator are:
  • Vehicle speed signal
  • Deactivator switch
The outputs of the speed control actuator are:
  • Speed control indicator lamp
  • Speed control actuator cable controlling the throttle position
2helpful
The blower fan on my 2004 gmc envoy runs high speed and will not turn off even when the key is off
You need to replace the blower motor speed control resistor, it is located under the glove box. You can watch the repair on Youtube on an 06 which is the same as your model and year.
Top Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
