With a backup camera I installed on my wife's Pathfinder, there was a power wire that connected to the backup light power. So when the backup lights came on in reverse, the camera got power, sent a video signal to the dash radio screen, and it would automatically switch to that input. You might have a bad wire/connection supplying power to the camera.
Testimonial: "Just found my post again. thank you for the reply's. Any suggestions on how would I go about checking the reed switch, broken wire, etc (where to look and tools needed) any suggestions are really appreciated."
The fact that your camera is factory fitted i would check for a reed switch at the gearlever its possible its dislodged or maybe a broken wire or bad connection
SOURCE: brake pads in lexus RX330 2004 model
If you email me at [email protected] i can attach instructions. Please remind me of your make, model and concern. thank you
SOURCE: Cracked screen on 2004 lexus rx330 nav unit
UNKNOWN BUT TOO REPLACE
IF YOU CAN SEE THE RADIO DON'T REPLACE IT
BUT ITS A LEXUS THE CAR IS 1 OF A KIND IT SELF BESIDES THE CRACK IN THE RADIO
GET A NEW 1 WITH BLUETOOTH by ALPINE and get yo stunt on its 2009
THE WORLD IS CRACKED NOT NAVIE GLASS
SOURCE: 2004 Lexus RX330 Battery Replacement
You just had to disconnect the negative off the old battery first. Then you disconnect the positive and it happens to touch metal it won't short anything out. Make sure you can not wiggle the cables, that the connectors at the battery can't spin or move at all. Tighten them more if necessary, try to start it. Let me know if you still have problems.
SOURCE: lexus rx330 electronic computerized key broke off. chip is ok
I got key shell for cheap on e-bay, replaced the chip from broken shell and locksmith cut me the key from original. Works great for total around $35
SOURCE: How to replace Lexus RX330 headlights.
replacing the headlights is easy. There is no need to adjust the afs, is is automatically done within the vehicle. Changing the bulbs doesn't affect the afs system at all.
I'm having same issue here. Put car in reverse and navigation stays on screen. It does not go blank black nothing. How do I test if power going to the camera and also checking the reed switch?
Me too. My car is es350 2010. I’m having same your issue Bret Gentry. Did you fix your camera.
