Slipping clutch
The hydraulic clutch wont cause slip, unless the slave cylnder piston is stuck. The hydraulic part just replaces the cable
If its a wet clutch make sure you are using motorcycle oil, some car oils can cause clutch slip, If your using a synthetic oil, you might try a mineral oil to see it it makes a difference, 600 miles is not enough to wear the plates
