Computers & Internet Logo
Posted on May 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have,nt got a problem,just enquiringif my asus p5kpl-vm motherboard,would be to support a[intelCORE 2Q6600/2.4hz/2X4MB/1066FSB/LGA77]CPU
Georgia B
Level 3:
Guru:
  • Master 1,342 Answers
  • Posted on May 04, 2008
Georgia B
Master
Level 3:
Guru:
Answers
1342
Questions
0
Helped
879474
Points
3834
Which motherboard is suitable in replacement of p5kpl-am/ps motherboard?
if you mean upgrade take a 1150 motherboard like z87 - plus or maximus VI if you mean replacing but keeping cpu then any p5kpl will do like ipc or -se -vm etc.
2helpful
I Have a P5K-VM, It posts and begins booting, then it shuts down
It might be a problem with your cpu fan, fire it up with the cover off and see if your fan is turning; most cpus will shutdown when they get too hot.
A need drivers of p5kpl-vm/s motherboards for windows xp service pack 2 supportable
Hi, try these links for your drivers:
http://www.getpcmemory.com/drivers/motherboards/download-asus-p5pe-vm-motherboard-windows-xp-drivers/
http://www.driverstock.com/ASUS-P5PE-VM-driver-download/6-9-10170-81103/index.html
Vcore voltage
check the cpu voltage to the board jim
3answers
Need drivers for asus p5kpl-vm
Just Make a Search on www.google.com
4helpful
ASUS P5KPL-VM does not start, blinking LED
u must repair ur mother board there is problem of power section . power ic get heat and than only working.enjoy good luck plz vote on my comments
Sutaible mother board of a size 9.61 x 9.61 inches. I am having a MB of Intel D865G & i want to replace it with Asus P5KPL, so please suggest me is it match all dimensions of D865? Thanks Rupesh
The Asus P5PKL motherboard has the dimensions of 12 X 7.6 inches.
The boards which exactly match your size requirements i.e; 9.6 x 9.6 inches are:
Asus P5P800-VM and Asus P5P800-MX
You can also have a look at Asus P5KPL-CM , P5KPL-VM, P5KPL-AM motherboards which have the dimensions of 9.6 x 8 inches.
Hope this solves your problem Thanks.
Can i use nvidia 8600 video card for my mother board asus p5pe-vm and processor intel core 2 duo to my motherboard
this are the CPU -s that you're mb can support (core 2 duo)the numbers after "All" are the bios version's you need for the cpu: Core 2 Duo E4300 (1.8GHz,800FSB,L2:2MB,65W,rev.L2) ALL 1201 Core 2 Duo E4400 (2.0GHz,800FSB,L2:2MB,65W,rev.L2) ALL 1202 Core 2 Duo E4500 (2.2GHz,800FSB,L2:2MB,65W,rev.M0) ALL 1406 Core 2 Duo E4600 (2.4GHz,800FSB,L2:2MB,65W,rev.M0) ALL 1406 Core 2 Duo E4700 (2.6GHz,800FSB,L2:2MB,revG0) ALL 1501 Core 2 Duo E6300 (1.86GHz,1066FSB,L2:2MB,rev.B2) ALL 0604 Core 2 Duo E6300 (1.86GHz,1066FSB,L2:2MB,rev.L2) ALL 1201 Core 2 Duo E6320 (1.86GHz,1066FSB,B2:4MB,rev.B2) ALL 1402 Core 2 Duo E6400 (2.13GHz,1066FSB,L2:2MB,rev.B2) ALL 0604 Core 2 Duo E6400 (2.13GHz,1066FSB,L2:2MB,rev.L2) ALL 1201 Core 2 Duo E6420 (2.13GHz,1066FSB,L2:4MB,rev.B2) ALL 1402 Core 2 Duo E6600 (2.40GHz,1066FSB,L2:4MB,rev.B2) ALL 0604 Core 2 Duo E6700 (2.66GHz,1066FSB,L2:4MB,rev.B2) ALL 0604 Core 2 Extreme X6800(2.93GHz,1066FSB,L2:4MB,revB2) ALL 0604 and for the graphic card ...no because you motherboard has the "AGP" interface and the nvidia 8600 has "PCI - express" interface as is described here: http://www.nvidia.com/object/geforce_8600_8500_tech_specs.html
1helpful
P5ld2-vm problem
go to "bios settings" by pressing "delete" key or F2 at the system start up time .. after going in to bios then search for the options load optimal defaults ....then save it and exit ..
after that restart ...
now have a check if your problem persists then the processor which you have choosed might not support the motherboard specification the frequency of the processor is higher than the specified rate .. check here for the details of the processor which supports your motherboard
Intel Core 2 Duo HH80557PG0332M BX80557E4300 E4300 1.8GHz,800FSB,L2:2MB,65W,rev.L2 1102 2.00G HH80557PG0332M BX80557E4300 E4300 1.8GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0412M BX80557E4400 E4400 2.0GHz,800FSB,L2:2MB,65W,rev.L2 1202 2.00G HH80557PG0412M BX80557E4400 E4400 2.0GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0492M BX80557E4500 E4500 2.2GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0562M BX80557E4600 E4600 2.4GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0642M BX80557E4700 E4700 2.6GHz,800FSB,L2:2MB,revG0 1401 2.00G HH80557PH0362M BX80557E6300 E6300 1.86GHz,1066FSB,L2:2MB,rev.B2 0901 2.00G HH80557PH0362M BX80557E6300 E6300 1.86GHz,1066FSB,L2:2MB,rev.L2 1202 2.00G HH80557PH0364M BX80557E6320 E6320 1.86GHz,1066FSB,B2:4MB,rev.B2 1202 2.00G HH80557PH0462M BX80557E6400 E6400 2.13GHz,1066FSB,L2:2MB,rev.B2 0901 2.00G HH80557PH0462M BX80557E6400 E6400 2.13GHz,1066FSB,L2:2MB,rev.L2 1202 2.00G HH80557PH0464M BX80557E6420 E6420 2.13GHz,1066FSB,L2:4MB,rev.B2 1202 2.00G HH80557PH0564M BX80557E6600 E6600 2.40GHz,1066FSB,L2:4MB,rev.B2 0901 2.00G HH80557PH0674M BX80557E6700 E6700 2.66GHz,1066FSB,L2:4MB,rev.B2
check the website given below for details :
http://www.cpu-upgrade.com/mb-ASUS/P5LD2-VM.html
thank you
rate my solution
Grand Canyon Tech
Grand Canyon Tech
