Spy Video ATV-360 Logo
Posted on Aug 17, 2010
Only my right wheel works the 360 button works on that tire but the forword/backword does not work the sound doesnt work,video doesnt work i need help
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 28, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
324
Points
The problem is that the circuit board has burnt itself out on the wheel motor and the camera and mic connectors may have disconnected
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Sep 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
597
Points
Dear Jacob0116,
Please contact me directly if you are still experiencing this issue!
Angela
Wild Planet Consumer Services
800.247.6570 x 198
I have a Canon MP480, has error message indicating paper jam, but there is no actual paper jammed.
TRY TO ROll THE PAPER ROLLER backword and forword and then power it up the printer and should be ok
2helpful
3answers
Sounds like a clunking noise, like the sound you hear when you have a flat tire, Tire isnt flat. turning right on the wheel lessons the sound but stays the same turning left. noise seems to be getting...
its a wheel bearing. .will need to be inspected to determine the correct one. Also tires could also do this if the steel seperated internally. Rotate the suspected tire to see if it follows the tire.
2answers
I have also tried the xbox on different televisions
as the console starts
press and hold the y button for 2 sec
then pull the right trigger but dont release the y button..
if your successfull, the console should restart..do it a couple of more times...
what you are doing is trying to reset the display to defaults
The video doesnt work but the sound does.
the first xbox 360 i ever fixed had the same results as this one, after applying the "x-clamp" fix it worked fine. if it is under warranty, contact microsoft, if not maybe you might want to look into fixing it your self, or searching for companies that fix this online.
2helpful
3answers
Xbox 360 Controller right trigger doesnt work
Your controller is most likely exhibiting a hardware failure. Taking apart the device voids your warranty. When a button does not work anymore, it is safe to say that you will need to buy a new controller.
The Logitech Chillstream Gamepad is only $20 and works in the same fashion as the XBOX 360 Controller (uses the same xb360 XInput controller driver too!)
Give that a look.
Xbox 360
make sure the TV in the correct mode, VIDEO, COMPONENTS.
if it was working before. a button might have been pushed by accident.
also your xbox360 may have died, you can try it on another TV to be sure, even though the lights come on doesnt mean the xbox360 is working.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
XBOX 360 no picture
try diffrent connectors composite instead of componant or vis versa. the wireless for the controls doesnt work on mine. I havent been able to find alot of replacement parts for the 360. I think you will end up having to send it in or by a used Core system for $200 from ebgames or ebay.. You could also try holding down the power button for 10 seconds. i heard that resets it as well.
Top Spy Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Spy Toy Expert? Answer questions, earn points and help others
