Maytag 24 in. MDBH970AWS Built-in Dishwasher Logo
Posted on Apr 27, 2008
DISHWASHER HELLER DWH3
WHEN I TURN IT ON THE SALT LIGHT IS ON AND THE MACHINE WONT DO ANYTHING ////
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
781
Points
My heller dish washer has a error code e4 ? where can i find what this means
1helpful
My Heller DWH3 is displaying error code 6. What does that mean?
The Heller DWH3 appears to be a Dishwasher, so I moved category from Laundry Washing Machines.
The Heller appears to be a little known make here in North America, and the only similar name 'Hella' I know makes car spotlights. If it shares codes with Haier, it is this, the Flood Protection Device and is very common. There is a tray and sensor in the base.
E6: All four lights flashing
Haier dishwasher E6 error code indicates that the flood protection device has been activated and the water supply will need to be turned off, stopping any more water from flowing into the dishwasher and leaking out.
Haier Dishwasher Error Codes Explained ' Exclusive Repairs
https://exclusiverepairs.co.uk > Blog
Dec 8, 2021 - The water inlet solenoid could also be defective. E6: All four lights flashing. Haier dishwasher E6 error code indicates that the flood ...
Feb 07, 2022 • Dishwashers
Dishwasher salt light wont go out after filling it with salt and everything is coming out white
well,if you fill it with salt and the salt light wont go out,and your dishes came out white,PLEASE STAY AWAY FROM THE DISHWASHER! the salt light is a warning light ,not to fill it but to delime it! wow,
Apr 23, 2015 • Dishwashers
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 • Dishwashers
What do these lights mean there not going off
7helpful
My bosh classixx dishwasher is showing the light rinse acid and salt i have just got finish rinse aid and salt **** not sore were to put it in the dishwasher there is a cap saying salt is it that?
Inside the machine in base there is a large screw cap.
Undo that put DISHWASHER salt in not cooking salt.
Make sure the salt well is full of water in it before you put in the salt. Fill salt to top.
Please dont forget to vote this answer was helpful
Many thanks
2helpful
4answers
Salt lasts only a very short time in dishwasher
go 2 the inside of dishwasher ull find settings from 1 to 6 simply turn back
My dishwasher model dwh3 manufactured by Heller is displaying error 3
my dishwasher has the same problem what is the solution?
Dishwasher not cleaning
hello kiwi
check the water level in machine this may be low due to pressure switch not sensing correct level try blowing back through air tube to clear any water from tube then try again
quick way is to start machine and when in wash mode check water and position of arms then add a litre or so of water in mid wash then recheck wash arms if they are now moving then you have water level problem
Feb 24, 2008 • Dishwashers
2answers
Rins aid and salt light wont cone on
They are alerts that only come on when you DON'T have enough rinse or salt.
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
