The compensator has a large nut on it and it's very tight. But, I get them off with an air impact wrench. You also have to remove the clutch assembly and primary chain. To remove the cluch assy, remove the clutch rod adjuster plate in the center of the clutch assembly by removing the snap ring. Inside the clutch is the mainshaft shaft nut. It has LEFT HANDED THREADS ON IT. Take it off and the remove the nut that holds the primary chain adjuster off and lift the front sprocket, the clutch, and the chain off all together.
The rotor should come right off but you'll have to put two bolts in the holes on the rotor and squeeze them together to get a grip on the rotor to pull it off. The magnitism force is quite strong.
When replacing the clutch and compensator, the mainshaft nut torques to 60-80 foot pounds of torque LEFT-HANDED. The sprocket shaft nut torques to 150-165 foot pounds. You'll need something to lock the primary chain while you torque the nuts or the engine will turn before you get them torqued.
Good Luck
Steve
