Question about Toshiba Qosmio G25-AV513 Notebook
I have a vertical line down the center of the lcd...I purchased new inverter and still the same...I purchased a used lcd and seven vertical lines popped up on the lcd...I plugged the G25 AV513 Qosmio to my desktop monitor and no lines...So would the problem be the LCD or something else.
    Problem Solver:
  • 9 Answers
That would mean its the lcd or cable ribbon bad idea to buy a used lcd!if its your video card would also show lines on monitor thats good!
Posted on Aug 20, 2010
Thin coloured lines running down center of tv. Panasonic Viera.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP TO SOLVE THE PROBLEM.....
Aug 07, 2011 | Panasonic Televison & Video
After turning on the tv. The screen shows up and down lines across the screen. Can't see much of the picture.
Hoping this will help in solving the problem...
Aug 05, 2011 | Sylvania 6620LCT 20 in. EDTV-Ready LCD...
Win 7, Samsung LCD, initial BIOS display. Then vertical lines. If choose BIOS setup also scrolling vertical lines (looks like barcode) Thank you!
If the lines appear in the BIOS (Basic Input Output System) setup, you are having problem with the LCD.
Here are some parts to check. Either you need to reinsert or replace.
- LCD cable
- LCD inverter
- LCD itself
Note: The LCD inverter fails often than other LCD assemblies.
Hope this helps.
Jun 27, 2011 | Computers & Internet
Thin red line across screen two inches for the top. Picture above line is good, picture below line has no color and double image.
Hope this will help out.....
May 12, 2011 | Vizio L32 32 in. LCD HDTV
I have vertical colored lines and cant read menu on my l32w761 envision lcd It seems to be shutting its self off also and the light blinks an orange color in place of the usual green
On all the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black line down the screen.
Good luck and take care in handling it ........
Jul 07, 2010 | Envision L32W761 32 in. LCD TV
A vertical line has appeared just off of the center of the screen. I have unplugged turned off reset and changed the background but the line stayed.
The vertical lines means you have failing T-CON board, part of the LCD panel assembly, it will get worst, new LCD panel will be needed. Westinghouse uses cheaply made screen like CheiMai, not LG/Philips.
http://s807.photobucket.com/home/budm/allalbums
May 19, 2010 | Westinghouse L1975NW Monitor
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Verical Lines in five or ten seconds after booting R50e ThinkPad
Possible loose connection from the inverter to the screen. you can try pushing the edges of the screen cover towords the center working your way around the problem area especially. But it could be just a bad inverter. Can you hook it up to external monitor? That will tell you if problem is before or after inverter.
Jul 14, 2009 | Computers & Internet
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
Toshiba Qosmio G25-AV513 Notebook Logo
223 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
