1. Press the Menu button 2. Highlight 'Messages', then press Select 3. Highlight 'Message settings', then press Select 4. Highlight 'Multimedia msgs.', then press Select 5. Check that 'Save sent messages' is set at 'No'. 6. Check that 'Delivery reports' is set at 'No'. 7. Check that 'Allow multimedia reception' is set at 'In home network'. 8. Check that 'Incoming multi-media messages' is set at 'Retrieve'. 9. Highlight 'Connection settings', then press Select 10. Highlight 'Active multimedia settings', then press Select 11. Highlight the next available Set (e.g. Set 1), then press Activate 12. Highlight 'Edit active multi-media settings', then press Select 13. Highlight 'Settings' name' and press Select (left softkey). Enter 'giffgaff MMS', then press OK 14. Highlight 'Homepage', then press Select (left softkey). Enter '
http://mmsc.mediamessaging.co.uk:8002' and press OK 15. Highlight 'Session mode', then press Select (left softkey). Highlight 'Permanent' and press Select 16. Highlight 'Data Bearer', then press Select (left softkey). Highlight 'GPRS' and press Select 17. Highlight 'GPRS access Point', then press Select (left softkey). Enter 'giffgaff.com' and press OK 18. Highlight 'IP Address', then press Select (left softkey). Enter '193.113.200.195' and press OK 20. Highlight 'Authentication type', then press Select (left softkey). Highlight 'Normal' and press Select 21. Highlight 'User name', then press Select (left softkey). Enter 'giffgaff' and press OK 22. Highlight 'Password', then press Select (left softkey). Enter 'password' and press OK 23. When asked to 'Verify new password' enter 'password' and then press OK 24. Press Back (right softkey) 6 times to return to the standby screen.
