ASUS P5KPL-AM SE Motherboard Logo
Posted on Jul 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have this motherboard ASUS P5KPL-AM SE with intel processor E6500 with 2 2GB 800MHz DDR2 Non-ECC CL5 DIMM KVR800D2N5/2G and a video card ATI HD4550 512 MB DDR3 what is happening is that my system after a while on idle it will begin a reboot as if it was loosing power and as long as I use the computer nothing happen.
Anonymous
Level 3:
President:
  • Master 995 Answers
  • Posted on Jul 28, 2010
Anonymous
Master
Level 3:
President:
Answers
995
Questions
Helped
293909
Points
3215
Have a system maintenance, clean-up unnecessary files, defragment your drives and have a full virus scan. If you encounter a blue screen then one of the computer hardware's is messing up. Remove newly installed hardware in your computer. If problem persist, replace your power supply unit with a higher wattage rate.
Thanks for using Fixya.
Is 2GB DDR2 PC2-6400 800MHz compatible with ASUS P5GC-MX/1333 if not what is the fastest and correct Ram I can fit;
From ASUS Site:
https://www.asus.com/us/Motherboards/P5GCMX1333/specifications/
2 x DIMM, max. 4GB, DDR2 667/533 MHz, non-ECC, un-buffered memory
Dual channel memory architecture
**When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
2answers
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Is the intel core 2 quad compatible with my ddr2 memory
Hello.
The motherboard ASUS P5KPL-AM SE is compatible with DDR-2 no matter what processor you are using, even Intel Core 2 Quad. So if that is your motherboard, then it is compatible.
3answers
My laptop is too slow even if i am just surfing internet like FB. can the memory be upgradable? up to how many gb?
you can upgrade up to 2GB (DDR2)
Your computer has 1 memory slot you remove the memory and install a new one.
you can use either
2GB 800MHz DDR2 Non-ECC CL6 SO DIMM
or
2GB 667MHz DDR2 Non-ECC CL6 SO DIMM
1helpful
3answers
I would to know if asus mother p5kpl am se iscompatible with window 7 ultimate 64 bits
yes it is. =) as long as your processor is compatible with windows 7 ultimate. this is the specs of your motherbard and I think it is pretty cool:
- Intel® Core™2 Extreme / Core™2 Duo Ready
- Intel® Quad-core CPU Ready
- Intel® 45nm CPU Ready
- G31+ICH7
- FSB 1333/1066/800MHz
- Dual-channel DDR2 800/667
- 4x SATA 3Gb/s
- Gb LAN
- 6-channel HD Audio
- EZ Flash2 & CrashFree BIOS3
please rate how this helped you.
2answers
P4vp-mx can support dual core proscessor, 2gb. ram and 512 video card
http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/#specifications
1 x AGP 4X (0.8V, 1.5V only) (graphic card AGP)
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
and if you click on the CPU Support List you see that it does not support Dual core processor :(
Which type of ram to fix in asus p5kpl-am/ps motherboard
2 x DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Maximum 4GB though.
If you go here:
http://www.asus.com/product.aspx?P_ID=y014Wy067iZxxPeP
and click on Memory/ Device Support tab you can download a document which is the Qualified Vendors List for available RAM for that particular motherboard.
1helpful
3answers
I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Product comparison
deal 2 is definatly better, go for it
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
