Hello I have a 1995 Cutlass Supreme. When I turn the key to the on position or start my car a relay on the driver side under the dash starts to click also my parking and brake lights start to flicker along with all my interior lights. Sometimes when shutting the car down the lights continue to flicker.
SOURCE: 1995 cutlass supreme transmission
It physically will fit and bolt up,but there are many different ratio,and drive and driven sprocket tooth counts,different final drive ratios,all monitored by the computer with electronic speed sensors.If the trans from the 95 has a different ratio than the 93,the computer will set gear ratio error codes,and possibly put the trans in a failsafe mode,stuck in 2nd or 3rd gear.On the transmission case,down by where the passenger side axle would go in,is a thin metallic tag,maybe 2"x 3",and it has bar codes,and also a series of numbers and letters.The numbers and letters,large cap,are the final drive gear ratio code.They should match on the two transmissions in question.
SOURCE: 1995 cutlass supreme HELP
You'll need to replace the turn signal switch. I had the same problem a few years ago and replacing the TS switch made everything OK
SOURCE: car won't start!!!
mine is doing the same... all i did was reconnect the battery...and it worked fine...but know my hood wont open!!! so i cant fix the cable on the battery!!! i pull on the darn cable so hard and the hood still wont budge!!!
SOURCE: 1995 cutlass supreme, auto-trans. shifter will not
Do your brake lights work? Sound like your shift interlock solenoid
