Computers & Internet Logo
A
Anonymous Posted on Jul 13, 2010
I have sd card which when I inserted in card reader it is telling it is not formated what to do
Anonymous
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Aug 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
2383
Points
24
Format your memory sd card
Anonymous
Level 3:
  • Master 1,234 Answers
  • Posted on Jul 25, 2010
Anonymous
Master
Level 3:
Answers
1234
Questions
0
Helped
294107
Points
1672
The First Way o Format Your Memory Card
Press Windows + R
IT appers a New Window
Write CMD In it
It appears Another Black Windows
Write in It
Format ?:
<< ?: >> Chnage The ?: With The Directory Of Your Memory Card
The Second Way o Format Your Memory Card
Open " My Computer "
Left Click In The Memory card
Choose Format
It Show's A Little Windows
Choose Fast Format
Then Click Format
If Nothing From This Ways Helps You :
Try This Tip : http://www.fixya.com/support/r5250548-flash_disk_usb
Please Rate If That Helps You Full
ADRIAN
Level 2:
Sergeant:
  • Expert 313 Answers
ADRIAN
Expert
Level 2:
Sergeant:
Answers
313
Questions
Helped
102295
Points
640
If there is data/photos on the card you need to save. Try downloading them with the card in the camera via the USB cable first. this will save your data. Then try formating the card either on the camera or your PC. Sometimes the cards get corupt and it is cheaper to replace them in the long term as this may happen again.
This could have happened by removing the card while the camera was on or by not using the card eject mode on your PC.
1helpful
2answers
How do i format an sd card for my panasonic lumix dmc-tz40?
I have got a Panasonic DMC TZ70 I could not find out using the manual how to format the memory card. I discovered how .. set the mode dial at the top of the camera to MANUAL, then select menu then you can keep arrowing down until you find FORMAT, click yes and it's done.
Format sd card
in formatting an sd card., you must have a memory card reader/. then insert it into the card reader, next right click it then format it....
I cant format my memory card and my cellphone cant read it to what should i do .
Get a Multimedia card reader for yourself. Plugin in the card reader in computer and insert the SD card in it. Once you see the SD Card in My computer that means your card reader is able to read the SD card that you have inserted. You can right click on the icon and click format. Do a quick format and choose file system as FAT32.
or
You can use SD Card Formatter and can follow their manual. I think that will also work for you. http://www.sdcard.org/consumers/formatter_3/
Cannot format my micro sd card
buy a card reader and insert the micro sd in the appropriate slot given in card reader and connect to computer.now you can format it like you format a usb drive.
2answers
I am getting error message that sd card is blank and/or when i want to use my camera error message comes as insert your sd card..i try to format the sd card by following format sd card section but nothing...
Try formatting your SD card by plugging in Laptop's or using a memory card reader. Don't use the cell, after formatting insert in cell and re-format. it will work.
2helpful
I got the message "Your Disk is Write Protected" when i go to format. How i format my Transcend disk. Please help me. Thanks.
Removing the write protection depends on the source of the problem.
Broadly speaking, it can be any of the following scenarios
  1. There is a write-protection tab on the mini sd card HOLDER. Every time you insert this into your PC or card holder, this tab slides to the write protect position. Either keep resetting, inserting & reinserting until it doesn't slide or tape it down.
  2. There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
  3. The mini sd card has some error: Go for a low level formatting.
  4. The card has virus: Remove the virus. The link for the steps is present in the related link at the bottom of the article.
There is an easy way to solve this problem: Simply put the yellow lock in the middle of its slider. No sticky tape required, as shown below. But if your still having the same problem i suggest you try the sticky tape.
problem is only that small moveable yellow lock switch is not making, just put sellotape over it maybe two layers needed to make switch.
== Answer == Even though what is written below may work, the problem is probably that on the card reader (if you have one) there is a small switch that has lock written on the side. If this is pushed down, the drive is write protected, push it in the opposite direction and it may fix your problem I had the same problem with several cards but eventually found a way around it. DON'T buy a new one!
Make sure the SD card lock is 'off' and then use thin, opaque sticky tape (ie non see-through; eg insulation tape) to cover the whole gap but keep clear of the metal contacts at the back.
Your card should work fine now... don't know why this has to be done, but it works! Additional info:
Reason #1,
the mechanical lock switch accidentally moves to the "locked" position during insertion due to the poor quality of the switch. Hence, by taping it, you are actually preventing the lock switch to travel towards the lock position. i.e. downwards.
Reason #2
If the above fails, it is likely your SD card reader/writer's fault. But don't discard it or buy a new one yet. Allow me to explain the mechanical design of the SD card lock mechanism. So that you may choose to repair it if you want to. You will need a small paper clip and screw-driver to open your card reader. (Don't proceed if your card reader is still under warranty, please return/exchange with manufacturer) There is a mechanical switch very much like a micro push button (I wish I could show you the picture/drawing). Anyway, depending on the position of the lock switch. You either push or release this micro push button inside the SD card reader.
Due to mechanical wear and tear, or some forceful insertion of the SD card, the micro push button is in its "open" circuit position, i.e. write-protected. In order to make the SD card reader writable, we will need to "close" the circuit. (Note: this is an irreversible process as I will be telling you how to remove the write-protection feature of your SD card reader. Once you do this, you would be unable to use the SD card lock switch to lock your data. So, just be careful not to accidentally delete your data)
To proceed, you need to remove the main circuit board from the SD card reader/writer enclosure. The location of the micro push button switch is the same location as the unlock position of the SD card when inserted in the SD card reader/writer. From the BACK of the exposed SD card reader, insert the unfolded paper clip (same way when you try to poke something like a device reset button) except, that it has to be long enough to allow the micro switch to touch together for contact. Then insert the SD card. Once the contact is "closed", your SD card reader/writer can write again. I understand that without a drawing, this may not be very helpful. Please provide suggestions or better explanation if you can. Thanks.
Or, just tape the lock switch to unlocked. This also works for SD cards in normal size. back up all the files u have on ur card then follow these steps
1. Go to Control Panel
2. Go to Administrative tools
3. Go to Computer management
4. From the tree menu on the left select Disk Management
5. Now on the right side you will have a list of all storage devices connected to your computer. Select the one that is your mini SD card. BE CAREFUL WHEN CHOOSING THIS BECAUSE YOU COULD FORMAT YOUR HARDDRIVE. Double check the name in My Computer
6. Right click on the SD card and select format. A new window will pop up showing format options. Select FAT32 from the file system drop down and check the quick format option and then click on OK
7. Enjoy your mini SD card without that annoying write protection
1helpful
C190 does not read the sd card even when sd card format is ok . it is giving a message 'memory card requires formatting' 'please format memory card or insert another card' however inserting a new...
Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • 1helpful
    I cannot get my konica minolta dimage g600 to accept sd card
    Hi
    the following memory types are supported byt your camera
    SD (Secure Digital) Memory Card / MultiMediaCard (MMC) / Memory Stick / Memory Stick Pro
    Do you have a card reader on your computer? We could format the card on the computer and then see if it works with the camera.
    Can you tell me the size of the sdcard?
    To format the card on your computer plug it into the reader, open my computer and find the card from there, ones you have found the right one from my computer right click and select format, Try formating the memory card to fat 12 or 16 and then when the format is complete insert it into your camera again.
    (turn off the camera, insert the card, turn the camera on)
    If the memory card still doesn't work plug it to the computer again and this time format it to fat32.
    If this ia new sd card with alot of storage do you have a smaller card that already works on the camera?
    2helpful
    Reformat sd card for tomtom one
    FIRST THING , Backup the SD card. To format an SD card you insert SD card into card reader slot on a PC or a SD card reader. Then find the SD card Icon in 'my computer'. Then hover over it with the mouse and right click , choose 'format' from that drop-down menue. REMEMBER .... EVERYTHING ON THE CARD WILL BE DELETED ! *** WARNING *** The card will not work in the tomtom once it has been formatted.
    1helpful
    Memory card cannot be used
    Follow these steps: 1. If you have a SD card reader, insert the SD card and look for it in Windows Explorer. In this case, mine was labeled F: 2. Right Click on the drive for the Card Reader (IMPORTANT) and choose FORMAT. 3. Format card with default settings. 4. Turn Camera on and go to MENU> FORMAT CARD 5. Before answering the next question, insert SD card into camera. You will hear it beep twice. 6. Choose FORMAT and the card should be formatted for use on the camera. Cheers!
    Grand Canyon Tech
    Grand Canyon Tech
