Foggy headlight assembly
If the fog is on the outside, it is damage from dirt and rocks from the road. You can try sanding and buffing them (they sell kits for this purpose), but it's not that easy.
If the fog is on the inside, it may be that moisture has gotten into the assembly through a crack or loose seam. Remove the protective backing from the assembly and let the water evaporate. Find the crack or loose seam and seal it with clear caulk of some kind.
The only other choice is to replace the assembly.
Best wishes!
