Cars & Trucks Logo
A
Anonymous Posted on Jun 27, 2010
Engine overheats and I've changed the water pump already along with the thermostat. What could be the problem?
Anonymous
Level 3:
  • Master 10,319 Answers
  • Posted on Jul 17, 2010
Anonymous
Master
Level 3:
Answers
10319
Questions
5
Helped
3075709
Points
30576
Many things can cause an engine to over heat
Look for any collasped water coolant hose. That will cause overheating'
If the inside of the engines oil cap looks to have a creamy filling in it that will be from coolant mixing with the engine oil. Head gasket leak and can cause overheating
A clogged up heater core or radiator can cause overheating
A loose or worn seal on the radiator fill cap can cause overheating as well
Overheating problem for 1996 Hyundai lantra sportswagon
If you have already checked the radiator, fluids, thermostat, and thermo fans and your 1996 Hyundai Lantra Sportswagon is still overheating, there could be other issues causing the problem. Here are a few other things you can check:
  1. Water pump: The water pump is responsible for circulating coolant through the engine and radiator. If the water pump is not functioning properly, it can cause the engine to overheat.
  2. Head gasket: The head gasket seals the cylinder head to the engine block. If the head gasket is damaged or fails, it can allow coolant to leak into the engine, which can cause the engine to overheat.
  3. Cylinder head: If the cylinder head is cracked or damaged, it can cause the engine to overheat.
  4. Engine block: If the engine block is damaged or has a crack, it can cause the engine to overheat.
  5. Clogged radiator: If the radiator is clogged with debris, it can prevent the coolant from flowing properly and cause the engine to overheat.
To determine the cause of the overheating problem, it will be necessary to perform a thorough inspection of the engine and related components. If you are unable to locate the source of the problem or are not comfortable attempting to fix it yourself, it is recommended to have the vehicle inspected by a professional mechanic.
2006 Equinox. Losing water. Over heats. Is this a thermostat or water pump problem??
Depends on where the coolant is going.
If it is an external leak it could be a leaking water pump. If there are no external leaks and you are loosing coolant, it could be a blown head gasket. Especially if the engine has already overheated once.
A sticking thermostat would cause the engine to overheat and then loose coolant from the overflow tank. But not until it overheats.
1999 Cadillac Eldorado ,overheating changed thermostat , overflow cap ,no white smoke coming from exhaust.hot blowing from heater
Are the cooling fans coming on ? Go under the hood in the engine compartment , with the vehicle running have some one turn on the A/C , do you see and or hear the cooling fans come on ? Could be the coolant temperature gauge is bad ! How many miles on the vehicle ? Ever have water pump replaced ?
Check for a loss of system pressure.
Is there a loss of system pressure?
Go to Step 2 yes
Go to Step 3 no
Inspect and repair any faulty hose connections.
Does the engine still overheat?
Go to Step 3 yes
System OK
Check for low coolant protection (-37?°C/-34?°F).
Is there low coolant protection (-37?°C/-34?°F)?
Go to Step 4 yes
Go to Step 5 no
Test solution. Replace the coolant if necessary.
Go to Step 5 yes
System OK
5
Check the water pump belt for low tension.
Is the water pump belt tension too low?
Go to Step 6 yes
Go to Step 7 no
6
Replace the water pump belt tensioner.
Go to Step 7 yes
System OK
7
Check for an inoperative thermostat bypass.
Is the thermostat bypass inoperative?
Go to Step 8 yes
Go to Step 9 no
8
Replace the bypass.
Go to Step 9 yes
System OK
9
Check the water pump.
Is the water pump inoperative?
Go to Step 10 yes
Go to Step 11 no
10
Replace the water pump.
Go to Step 11 yes
System OK
11
Check the radiator fins for obstruction.
Are the radiator fins obstructed?
Go to Step 12 yes
Go to Step 13 no
12
Inspect and clean the radiator fans.
Go to Step 13 yes
System OK
13
Check the cooling system passage for obstruction.
Is the cooling system passage blocked?
Go to Step 14 yes
Go to Step 15 no
14
Inspect and flush the system. Reroute or replace the hose if necessary.
Go to Step 15 yes
System OK
15
Check the water pump belt for damage.
Is the water pump belt damaged?
Go to Step 16 yes
Go to Step 17 no
16
Replace the water pump belt.
Go to step 17 yes
System OK
17
Check the cooling fans.
Are the cooling fans inoperative?
Go to Step 18 yes
Go to Step 19 no
18
  1. Inspect the electrical connector. Replace if necessary.
  2. Does the engine still overheat?
Go to Step 19 yes
System OK
19
Check the throttle body circuit flow.
Is the throttle body circuit flow restricted?
Go to Step 20
Go to Step 21
20
  1. Inspect the orifice and associated hose. Replace if necessary.
Go to Step 21
System OK
21
Check for a stuck thermostat.
Is the thermostat stuck in the closed position?
Go to Step 22
22
Replace the thermostat.
System OK
Egine overheats
You did not mention the Thermostat which controls the temperature of the engine. Did you mean the Thermostat when you said temp sensor? If not, then change the thermostat.
2helpful
2answers
1988 b2200 is overheating--we've changed out the lower radiator hose, thermostat, and the upper hose is fine. Why is it overheating? Radiator, heat pump, or water pump?
!st check and make sure the water is flowing in the radiator, then check
the timeing, Mazda will run hot if the timeing is rong.
2answers
1990 subaru legacy- overheats, I"ve
Most likely you put the thesmostat in upsid down. Good luck
The engine overheats, Iunderstand the 97 Taurus has a water pump problem
Replace the water pump and thermostat if you already are aware that you have water pump going out.
Thank you for using fixya.com
My o1 grand am v6 overheats , just put in new t/stat and still overheats . how can i tell if the rad cap is bad
Where does water come out,if at all?It probably is a water pump since you already changed thermostat.Probably takes 15-20 minutes of good running speed to overheat?Greg
4helpful
3answers
I have a 97 bmw 316i, we have changed the water pump, checked heads and changed radiator, bleed it at a 40degree angle filled it with coolant and it is still overheating after a ten minute drive?
You actually need the thermostat in to pressurize your cooling system or the coolant won't cyle through the radiator, it'll just cycle around the engine. Most people think without the thermostat in the coolant will just pump freely through the engine and radiator, but it doesn't.
Chuck in a new thermostat, purge the air out of the system and see if it overheats then. I gaurentee it won't, if it does then you've got head problems (but they should already be obvious by now).
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
