My handle bar mounted Harley Davidson Road Tech HA90 MP3 Player has played well for four years but now the unit will turn on start to play a song and then shut off or it will light up & then turn off and/or then sometimes won't turn on again until the bike is shut down completely.
Hi there it seem as if the MP3 player is experiencing a power problem that causing it to shut down,you should check the power connector that supply power it may be shorting the power to the MP3 player.
Sounds like a chip is fried. If it is 4 years old, and you try to have it repaired, it might be cheaper to just get another mp3 player.
It sounds like the battery is dying. Most of the time when a unit can't easily turn on, the battery is at the end of it's life. Replacing the battery should get it going again.
How do I replace the battery in my handle bar mounted Harley Davidson Road Tech HA90 MP3 Player?
Thanks tbreeze47,
You said that the problem my Harley Davidson Road Tech HA90 MP3 Player is thatthe battery needs to be replaced.
How do I change the battery in the player?
How do I access the MP3 Player's battery?
I've been advised that my Harley Davidson Road Tech HA90 MP3 Player battery needs to be replaced.
How do I access the MP3 Player's battery and change the battery in the player?
My handle bar mounted Harley Davidson Road Tech HA90 MP3 Player will turn on start to play a song and then shut off. I've been advised that my battery needs to be replaced. How do I access the MP3 Player's battery and change the battery in the player?
