Computers & Internet Logo
Posted on Jul 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My computer wont start up and so i ran a bios primary hard disk self test and it says failed test status 7 (completed with the read element of the test failed) my computer is a hp netbook mini 1000 what can i do what is wrong with my computer? help please
Anonymous
Level 2:
Novelist:
  • Expert 144 Answers
  • Posted on Jul 13, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
144
Questions
Helped
50231
Points
359
If it is within warranty, send it back quick-smart.
sounds like the SSD (solid state drive) has died.
i got one of these errors at work on a Dell mini only yesterday!
Beep problems and Hard disk not recognizing
The single beep you hear when your computer boots is the completion of the POST. Power On Self Test. If there is an issue with your computer you will experience what you are hearing. If you have already verified your hard disk is connected then I would have to say either your primary hard disk controller failed or the drive itself failed.
My hp womt start up the quixk start lighta cpme on then notging
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
If there is a problem with the LCD display's back light or a corrupted graphics driver, the display may appear blank but the notebook may be displaying information. Attach an external monitor to test the display. If the image displays on the external monitor, there may be a graphics driver conflict. To resolve this, turn on the computer and press f8 key, then select Enable low-resolution video . If the image displays on the LCD display in low resolution, you can download and install the latest drivers for your specific graphics driver. If there is an image on the external monitor but the notebook display remains black, contact HP for technical assistance.
Even though users are instructed to disconnect all peripheral devices from the notebook when doing a hard reset, some devices are often overlooked.
Double-check that all devices are disconnected including: external keyboard and mouse (wired or wireless), USB connected external drives and devices, thumb drives and flash drives, network storage devices, PC card, SD memory cards, express card, eSata connections, firewire or similar devices, printer, scanner, camera, port replicator, or docking station, any CD/DVD from the optical disc drive, and any media from the multi-card reader.
If the computer can access part of the memory, it may be possible to access the BIOS Setup Utility display and perform a memory self test to identify other memory issues. If the computer cannot boot to the BIOS Utility, try removing and reseating the memory and the hard drive, and then repeat the following steps to perform the memory self test.
  1. Plug the AC adapter into the computer.
  2. Turn off the computer and wait 5 seconds.
  3. Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup menu.
  4. In the BIOS Setup Utility, use the Right Arrow or Left Arrow keys to navigate through the menu selection to locate the Diagnostics .
  5. Use the Up Arrow or Down Arrow keys to select Memory Test .
  6. Press Enter , and then Yes to perform memory test.
  7. After test completes, press f10 to Save and Exit , and then press Enter to Exit Saving Changes? .
Many computer problems are related to soft failures (or degraded performance) on the hard drive. The HP Hard Drive Self Test will repair soft errors on the hard drive, but it will not report the errors. After the test is complete, restart the computer to see if test repaired the problem you may been experiencing. Use the steps below to test the hard drive in a computer using the HP Hard Drive Self Test.
Plug the AC Adapter into the computer.
Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup Menu.
Use the Left Arrow or Right Arrow keys to navigate through the menu selection to locate the Primary Hard Drive Self Test option. Depending on your BIOS, this may be located below either Diagnostics or Tools .
Select Primary Hard Drive Self Test , and then press the Enter key to start the test.
Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer.
Turn off the computer and wait 5 seconds. Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup menu.
Use the Right Arrow or Left Arrow keys to navigate through the menu selection to locate the Primary Hard Drive Self Test option. Depending on your BIOS, this may be located below either Diagnostics or Tools .
  • Select Primary Hard Drive Self Test , and then press the Enter key to start the test.
  • NOTE: The exact wording of the option for your particular BIOS may be slightly different.
    1. If Windows does not start properly, reset the BIOS to the default settings. Using the default settings, you should be able to boot into Safe Mode and install the latest BIOS. To reset the BIOS, press the power button to start the computer and repeatedly press the f10 to enter the BIOS setup, then press f9 key to Reset BIOS Default . For more information, refer to the HP Notebook PCs - Configuring the Boot Order in the System BIOS support document.
    2. If it will not boot to the BIOS, you may need to remove and re-seat the hard drive. Instructions may vary depending on the notebook model you are using. For specific instructions on re-seating the hard drive in the notebook, refer to the HP Notebook PCs - Steps for Removing and Replacing the Hard Drive support document.
    3. After re-seating the hard drive,perform a hard drive reset.
    It said problem on hard disk, install hard disk.. how to install where to get it my netbook has no dvd/cd compress HP mini
    Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer. If the computer has two hard drives, you should select the multi-bay test option and test each drive separately.
    1. Plug the AC Adapter into the computer.
    4. Use the Right Arrow or Left Arrow keys to navigate through the menu selection to locate the Primary Hard Drive Self Test option. Depending on your BIOS, this may be located below either Diagnostics or Tools .
    5. Select Primary Hard Drive Self Test , and then press the Enter key to start the test. NOTE: The exact wording of the option for your particular BIOS may be slightly different.
    The Hard Drive Self Test performs a Quick Test followed by a Comprehensive Test . During each test, the window displays a status bar and an estimated time to completion. See HP Notebook PCs - Testing a Hard Disk using the Built in Self Test for additional information.
    • If any test fails , contact HP service and support for instructions on how to order a replacement hard drive.
    • If all of the tests pass, the hard drive is not damaged. As a rule, HP will not replace a hard drive under warranty that does not fail the HP Hard Drive Self Test.
    • If there is no physical problem with the hard drive or memory, then try reinstalling your Windows operating system to troubleshoot the problem.
    Instruction on how to Install a new HDD
    Please follow the link
    Thanks
    Proton
    2helpful
    Dell studio windows failed to start. error code 2000-0146
    the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
    in case of your error DST log contains previous error(s) doing a
    chkdsk /r or a repair reinstall of xp might resolve the issue.
    to resolve issue...
    Error Code Error Message 1000-0141
    or
    2000-0141 No Drive Detected 1000-0142
    or
    2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
    or
    2000-0143 Drive Smart Read Command Failed 1000-0144
    or
    2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
    or
    2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
    or
    2000-0146 DST Log contains previous error(s) 1000-0147
    or
    2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
    or
    2000-0148 IDE ERROR: status (x) (s)
    Hard drive crashed
    NOTE:
    If it fails then you need to replace the HDD. If you can provide me the product no. then I would be able to find the exact part no.of the HDD.
    Dreamkam
    Windows xp would not boot up so ran primary hard disk self test and got a test status #2-07 fail. What does this meam and how do I fix the problem
    Its a Hardrive Problem you could try taking out the hardisk and cleaning the pins.. and plugg it in..
    if that doesnt fix the problem you will have to press F8 While Booting the Bios test, then choose last know config, or save mode with command prompt
    then type chkdsk /f and restart your computer.
    17 inch monitor goes blank
  • Prepare to diagnose the computer .
    1. Disconnect all peripheral devices.
    2. Perform a Hard Reset.
    3. Disable the Automatic restart on system failure option.
  • Remove any non-system disc from the computer . During startup, the BIOS checks different devices to locate the Windows operating system. If the boot order is set to check the optical disc drive or the card reader (if the notebook is equipped with a card reader) before it checks the hard drive, and there is a non-system disc in the CD/DVD drive or there is a memory card in the card reader, the boot will fail. This problem can be resolved by setting the BIOS to check the hard drive first.
  • Reseat the memory modules . If you are getting memory errors, most BIOS versions have additional tests that can be run to test the memory. There could be a problem if one of the sticks is defective or loose in the memory slots. To determine what is causing the memory failure, disconnect all electrical power, and then remove and re-insert the memory modules firmly into the slots. Some HP Notebook PCs come with two sticks of memory and have two memory slots. On most notebooks, the memory module compartment is located on the bottom of the case, but the exact position varies by model. On some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
  • Reset the BIOS to default condition . If you have made changes in the BIOS setting, such as disabling a device or changing the boot order, it could prevent the computer form starting properly. To restore the BIOS to its factory-recommended settings, turn on the computer and press f10 to access BIOS setup, and then press f9 to load the default BIOS configuration.
  • Perform a memory self test . There are different reasons that you may see a memory error. There could be a physical problem or it could be a program error. If the error is a program error, you will most likely see a Windows error message. If there is a physical problem with a memory module, the computer may fail part way through the boot process. Most computers have a built-in memory test to help identify if the memory modules are seated properly and are free of errors. To run the memory test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Start-up Test to run the system memory test. Press the Esc key once the memory test is complete.
    • If the BIOS Diagnostics screen displays, select Memory Test .
  • Reseat the hard drive . If you get a specific hard drive error message on a black screen indicating the hard drive error, reseat the hard drive. If the computer has been dropped or jarred, or the hard drive has been replaced recently, the drive may not be seated tightly. The hard drive LED should blink if the hard drive has a solid connection in the notebook. Refer to the on-line User's Guide for specifics on locating and removing / replacing a hard drive. HP provides video directions for performing this task for many computer models. Remove and reseat the hard drive firmly into the mounting bracket.
  • Test the hard drive . If you get a hard drive error message, you can test the hard drive. Many computer problems are related to soft failures (or degraded performance) on the hard drive. The HP Hard Drive Self Test will repair soft errors on the hard drive, but it will not report the errors. After the test is complete, restart the computer to see if test repaired the problem you may been experiencing. To run the hard drive test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Hard Disk Test to run the hard drive test. Allow the Quick and Long Hard Disk Self Tests to run.
    • If the BIOS Diagnostics screen displays, select Primary Hard Disk Self Test . Allow the Quick and Long Hard Disk Self Tests to run.
  • 3helpful
    D610 DST Short Status Test Fail
    It appears your hard disk has died and it may not be possible for you to retrieve your data.
    Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
    There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
    Grand Canyon Tech
    Grand Canyon Tech
