A button was stuck so i took the remote apart and put it back together.
Davidauriti
If none of the lights light up on the top of the remote when you press/release Select, check to make sure the batteries are placed correctly in the remote. If they are, you may need to readdress the remote to the receiver. I have provided instructions on how to program the remote to your receiver. I hope this helps.
Program remote, step 5:
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Hello walker3putt, my name is Michael Hurst with DISH Network. Is this remote an IR or UHF? There are ways of reprogramming the remote to the receiver. If this is and IR remote for an independent receiver then you can try pulling the smartcard out and System Information will come up on the TV. Look at the Remote Address on the TV and write down the number. Then Hold Sat until all lights on top of remote light up. Let go of the Sat button and pick a number from 1-15 and then press # and Record. Your remote address should change. If there isn't a smartcard in the receiver then try the menu button on the front of the receiver. If this is a secondary remote and is UHF you will have to take remote 2 to the room where the receiver is located and follow the same steps.
